Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 06-11-2006, 01:28 PM
Dimensions Dimensions is offline
Thinking of Buying an LS
Hey guys, I'm looking at getting a 2000 Lincoln LS. Found it on Craigslist.com.
http://boston.craigslist.org/car/169023725.html
What should I look for? What kinda of things should I check? Thanks a lot.
Old 06-11-2006, 03:57 PM
Frase's LS's Avatar
Frase's LS Frase's LS is offline
Send a message via AIM to Frase's LS
Re: Thinking of Buying an LS
just got mine a few weeks ago. make sure that it is shifting fine. make sure that all the windows go up and down fine. check under the engine cover (easy to remove) to make sure that the valve cover gaskets arent leaking. that is the biggest problem with the 00 ls. Oil leaks into the coils and spark plugs and causes misfires. i bought mine with that problem and it ran me $300 to fix. other than that, look for moisture in the headlights and fog lights. good luck
Old 06-30-2006, 06:04 PM
noex noex is offline
agree with the above.
Old 07-01-2006, 03:20 PM
Nic_Canada Nic_Canada is offline
I also agree, plus check for rust underneath the rubber above the rear wheels.
