Go Back   Automotive Forums Car Chat > Kia > Sedona | Carnival II
Old 06-11-2006, 12:06 PM
itaricans itaricans is offline
reset air bag light
hi!
does anybody knows how to reset the air bag light? mine came on, went off, came on again and stayed on since, (almost a month) any ideas?
thanks. louie
Old 06-29-2006, 10:18 AM
MeettheCreeper's Avatar
MeettheCreeper MeettheCreeper is offline
Re: reset air bag light
you need to access the air bag module with the proper scanner to turn the light off.
Old 07-14-2006, 10:06 PM
fastkia fastkia is offline
Send a message via Yahoo to fastkia
not sure if you're still trying to do this but if you are you need to find out what the codes are then repair the problem then u can undo batt and the light will stay off if problem fixed. If you don't have a way to check codes normally sedonas have a tendancy to brake driver's and passenger's (front) seat belt buckles if you inspect the whole wire you will see is cut if this is your problem hope it helps
