Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 06-11-2006, 02:30 AM
Chiquae07's Avatar
Chiquae07 Chiquae07 is offline
Send a message via AIM to Chiquae07 Send a message via MSN to Chiquae07
im startin to get depressed....
so far i cant find much aftermarket for my '01 b15 sr20 2.0L sentra. most of everything has to be custom. i got a pop charger so far and nothin else. ik that hotshot has a nice header for it. i cant seem to find a decent cat back exhaust for it. im wondering if im going to have to go custom or if there is a company that i am looking over possibly??? btw, does the muffler brand matter as long as its not a huge ones taht is over 2 1/2 inlet and is a straight through design? thanks in advance. just want to know if i have to go custom or not.
2008 Mazda 6 ATX 2.3 Liters of Slowness
For those 9 seconds it takes me to reach 60mph, will be the most fun ill have in this car.
Old 06-11-2006, 05:49 PM
nismo_pilot nismo_pilot is offline
Send a message via AIM to nismo_pilot
Re: im startin to get depressed....
hks makes an exhaust you may have to pick it up used though, check out jgy customs for sr20 parts
Old 06-11-2006, 05:56 PM
fugiot's Avatar
fugiot fugiot is offline
Send a message via MSN to fugiot
And quit worrying so much about the exhaust. Get some JWT cams and an ECU. Some pulleys or something. All mods for the MOTOR are easily found. Screw the exhaust.
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec.
VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec.
Don't make me ANGRY
Or I will kick you in teh NUTS
Your NUTS will feel teh steel toe
Teh steel toe that has been in teh snow
I will rip off yuor pants and kick yuo in teh nuts
My steel toe will stick to yuor nuts
And I will swing yuo around by yuor nuts as I do a Hurricane kick
Old 06-11-2006, 05:58 PM
yeah you can pick up a universal muffler thats not too ricey and have a 2.5 cat back custom built, dont worry about your mandrel bends unless youre going turbo
Old 06-11-2006, 11:52 PM
Chiquae07's Avatar
i think ive given fugiot a heat attack. ill figure something out..keep u guys posted.
Old 06-12-2006, 04:29 PM
ProZach626's Avatar
ProZach626 ProZach626 is offline
Send a message via AIM to ProZach626
You want me to ask the guy in my town where he got his neons and aftermarket wing for his sr20? :P jp
Old 06-12-2006, 05:49 PM
slideways...'s Avatar
slideways... slideways... is offline
cams, put a hotshot CAI tube with the pop charger on the end, headers, if you want, it may be worth it to get head porting and valve work done, as the SR20 head isnt a spectacular flowing head(especially the low port).
you can get some forged 300zx n/a pistons(raises compression to 11:1 and requires a 1mm overbore and VERY slight modification to the small end of the rod to fit, any machine shop can do this)
if your big balla you can get the TODA SR22DE stroker kit (hahah like 8k but its so sexy)
http://www.todaracing.com/products/n...ngine_kit.html
then after your 11:1 SR22DE that revs to 8k is done, your exhaust can come later
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 06-12-2006, 07:07 PM
ProZach626's Avatar
omg, why so expensive?!?!?!? What kinda gains would you get from a kit like that? Would it just be cheaper to tubro the sr20?
Old 06-12-2006, 07:43 PM
Chiquae07's Avatar
omgsss meng...like 8k ? lol thats crazy, its like more for that then the whole car itself. otheriwise idk how much i would benift from having the cams. its a real possiblity, but idk if spendsing 524 or so on cams and just give the car to my brother. ill save and grab an older 96' or so sentra se-r and build that to kill things.
Old 06-12-2006, 10:41 PM
cheaper to turbo yes. but increase in displacement not only adds quite a bit of torque and hp at all rpm, but it allows the motor to be able to handle more hp without being a completely strung out high-rpm-only race machine.
but you want some expensive stuff...
http://www.tomei-p.co.jp/_2003web-ca...x-com-eng.html
now granted you may have to be creative as they are supposed to go into a RWD car but id bet you could get them to fit.
(btw 114 yen is about 1 dollar)
but theres parts EVERYWHERE for SR20s, you just have to look and be a little creative. almost any silvia/240sx SR20 part will fit your car, except like possibly the clutch/flywheel (not sure if they fit).
now this kid has an HKS exhaust...id call HKS, Apex'i, and other companies and ask them directly if they make one for your car
http://community-2.webtv.net/Racer_X_91/Jims01Sentra91/
Old 06-12-2006, 11:46 PM
Chiquae07's Avatar
i know that hks does, but its only the muffler for about 345 or so, not the pipe from the cat like other vehicles. i think i'll prob do the universal and get custom piping. btw, how much of a gain can i see on the cams? i would go with the cams and the new valve springs on that as well. i did check that out though. apexi is univeral, no one that i kno of makes if directly for my model i should say, but for the overall sentra it should. idk if a exhaust for a spec work since every part on that car will fit unless is an engine part.
edit. i just thought of this, would i have to have an ecu tune to run the cams with the springs and adj cam gears?
Old 08-02-2006, 02:23 AM
SikEnCide's Avatar
SikEnCide SikEnCide is offline
Send a message via AIM to SikEnCide
weapon r makes intakes and headers.. i actuly just ordered one of their intakes ill let you know how it works out.
Old 08-02-2006, 12:48 PM
Chiquae07's Avatar
weapon r is basically trying to copy hot shots intake and i havent heard anything about their header.
Old 08-02-2006, 01:02 PM
SikEnCide's Avatar
copy or not its still an intake.
Old 08-02-2006, 05:15 PM
you dont need an ecu tune to run cams/cam gears, but a piggyback can help get more power from them.
