Old 06-11-2006, 12:16 AM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
shift linkage pin help
ok i cant get these things out on either of my d or b series..i removed the safety clip and i have a punch set that i got tonight..do i punch it from the bottom or top cuz it is stuck in there really bad! did anyone else have this problem??
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
Old 06-11-2006, 02:26 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: shift linkage pin help
jack the car up as HIGH as possible. You may need to shove a few tires or blocks under the car itself, like under the footweels. You can use a hammer, but it's easier if you have a 3 or 5 lb. mini sledge hammer. Use a punch or equivalent that is just smaller than the pin hole, but larger than the pin itself (so that it doesn't go inside the center of the pin). It will pop out with a few whacks with the 3 or 5 lb hammer...but may take a few more wacks with just a regular hammer. It will come out though. I have taken them out from the top, but it was a bitch and took about a 1/2 hour of straight hammering onto a phillips screwdriver. The screwdriver was about as useful as tits on a bull when I was done.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 06-11-2006, 11:44 AM
Hybrid1990crx's Avatar
if you end up not being able to get it off, you can pull the motor with the linkage attached and then its much easier to remove bang it out like that.
Old 06-11-2006, 11:54 AM
bambam89lx's Avatar
AF - Advisor
good point...didn't even think of that, although that's what I usually do.
Old 06-11-2006, 12:15 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
if you have access to an air compressor get an air hammer and with the proper bit you can just air hammer it out, really simple.
air tools = time saver
2002 Acura TL Type S
1991 Honda Crx Si
Old 06-11-2006, 12:41 PM
as long as you don't abuse air. If you know what I mean then you know what I mean.
Old 06-11-2006, 01:55 PM
4twenty's Avatar
4twenty 4twenty is offline
hahahahahaha its easy to get carried away with air tools
Old 06-11-2006, 03:26 PM
k thanks for the help ill have to try it when i go home next..the motors are out of the car im workin on my b16 outside of the engine bay so its easier then hopefully tomorrow ill just lower it in. when i removed the old si motor i just left the linkage on while i lifted it out cuz it was a pain to get to it under the car..but ill just raise up my b with the hoist and take some whacks at the pin. i was tryin to hit it from the top but ill try from the bottom and hopefully get it out. im gettin a sawzall tomorrow to cut out my front mount since i dont need it anymore.
Old 06-12-2006, 03:17 PM
I dont know what you mean but it doesent sound safe....
1991 Honda Crx Si
Old 06-12-2006, 04:00 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
He means that you only use air to remove stuff, air is very powerful and by no means a precision tool. You can snap a bolt in a second with your little finger, definately need to be sensible with air tools.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 06-12-2006, 05:04 PM
it means don't be a lazy fuck and use air for everything.
Old 06-12-2006, 09:26 PM
FrodoGT's Avatar
^Ditto, he said it better..with less words lol.
Current project:
Rio Red 91 hatch.
Old 06-13-2006, 02:41 PM
alright guys i got the shift linkage on but the shifter arm with the circle on the end doesnt have a bushing. im guessing one goes there cuz my old arm has one there but dont kno what kind i need to attach it to the tranny. im gonna call some dealerships today to try and figure it out but let me kno if youve had the same problem.
Old 06-13-2006, 03:10 PM
bambam89lx's Avatar
AF - Advisor
yep, one goes there. You're better off with an energy suspension bushing, but you can order one for a 90-93 integra from honda, or just get one from the junkyard.
Old 06-14-2006, 12:43 AM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
yeah my friend got worried about that. we bought the hasport b into a crx shift linkage and it dident come with the bushings. we got it with the motor tho. the whole swap.
