Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-10-2006, 06:39 PM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
how to test isc
i had to get my ecu rebuilt and replace my isc cause they said that was the cause of my my ecu going out. now i put one on from another car but i want to check and make sure its perfectly fine before i put my ecu back in. should i use a volt meter and see what it is runing or is there another way. cause if i dont have to spend the 230 on a new one ill be really happy
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
Old 06-11-2006, 12:20 AM
Eclipse4ever's Avatar
Eclipse4ever Eclipse4ever is offline
Re: how to test isc
Same with me. my IAC or also known as ISC is bad. how can I test another one that I want to put in if its good before I swap it. Also who has a IAC for sale ?
1997 Eclipse GSX
Old 06-11-2006, 07:11 AM
Re: how to test isc
yea i definetly want to test it first im not paying another 200 to get my ecu rebuilt and then having to wait 2 weeks so far for it to get done and i still dont know when its going to get here
Old 06-11-2006, 10:40 AM
ned032002's Avatar
ned032002 ned032002 is offline
Re: how to test isc
I have a used throttle body but I'm unsure of the condition of the IAC.
Old 06-13-2006, 12:00 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: how to test isc
Idle speed control servo is located on throttle body. When ignition switch is in ON position, operating sound of stepper motor should be heard over sound of idle speed control servo. If no operating sound is heard, check stepper motor circuit. If circuit is good, stepper motor or ECU is suspect.
Disconnect idle speed control servo connector and measure resistance between terminals 2 and 3. See Fig. 11 . Resistance should be 28-33 ohms at 68°F (20°C). Measure resistance between terminals 5 and 6. Resistance should be 28-33 ohms at 68°F (20°C). Measure resistance between terminals 5 and 4. Resistance should be 28-33 ohms at 68°F (20°C).
95 Talon TSI AWD
97 Eclipse GST
