Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 06-10-2006, 06:05 PM
scotty2756 scotty2756 is offline
alarm system sucks still having problems
1993 lincoln town car cartier stock alarm system i disconnected the switch under hood it was bad you cannot order it from ford anymore so i will have to hunt it down you cannot disable the alarm by pulling a fuse because it is tied into many fuses that control other functions of the vehicle the alarm goes off whether you set it by letting the alarm light stay on for thirty seconds but it still goes off eventually even if it is not set and i lock all the doors manually i do not know if you can disconnect the alarm module because im not sure if it will disable other things on the car i do not even know where to begin on checking to find the problem because it is tied into so many things on the vehicle if their is anyone out there that knows a simple way to disconnect the alarm altogether without screwing up other things on the car please help the ignition is different i have the original keys for the doors and i need to find a new switch for under the hood this is really a headache to diagnose and repair or discoonect the alarm thanx scottymy car was towed today gonna cost 300 bucks to get it back is there a fuse for the horn i can pull or can i disconnect the alarm help please
Old 06-11-2006, 11:54 AM
Mr Wiggl3s Mr Wiggl3s is offline
Banned
Send a message via AIM to Mr Wiggl3s
Re: alarm system sucks still having problems
This thread might help you:
http://www.lincolnsonline.com/forum/...ighlight=alarm
Old 06-12-2006, 09:51 AM
Towncar's Avatar
Towncar Towncar is offline
Originally Posted by scotty2756
...this is really a headache to diagnose and repair or discoonect the alarm...
Crap! Hmmm, I wonder if your 93 has a Drivers Seat Sensor that keeps the alarm from setting if there's someone sitting in the seat?
-Steven
1996 Town Car, Cartier
Old 06-14-2006, 10:09 PM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
Hello
I know for a fact that the 93 TC has a sensor in the bottom of drivers seat. Steve might be on to something there. You could locate it and jumper the wires. It's located on the underside of the seat. If you think that might be the problem I have a good one I could sell you.
Mike
Old 06-22-2006, 02:13 AM
my car was towed today while i was at work gonna cost 300 bucks to get it back is their a fuse for the horn i can pull or a way to disconnect this stupid alarm somebody help please
Old 06-22-2006, 08:35 AM
Hi there
You got your car towed because of the alarm going off ? That really sucks. You could disconnect the horn, untill the you can get the problem fixed. Did you try to jumper or disconnect that seat sensor like I sugested. Steve had mentioned above that the alarm might not be seting properly because of that seat sensor. The sensor is a long metal strip and has some blue plastic on it. You should be able to see it on the bottom of the seat, between the foam and the wire mesh. Good luck on geting that fixed.
Thanks Mike
Old 08-17-2006, 12:09 AM
problem is solved finally their is a control module located on the right front passenger kick panel it has two plugs a input and a output i disconnected the plug from the input side thus everything including keyless entry still works the alarm will go off now only from the the remote control finally the problem is solved thanx for all the help out there i think that the alarm module is no good one of my horns burned out i will replace that as far as the alarm module i think i will leave it how it is for now
