Old 06-10-2006, 04:07 PM
Jcrane88 Jcrane88 is offline
Send a message via AIM to Jcrane88
Electric cooling fan
my Z28 has had a engine swap..and taken old school..but it has a electric cooling fan..the cooling fan doesnt turn on at any temp..........there is a splice on one of the 2 wires and if you touch that to the battery it comes on.....the question is...what controls the fan? the computer ? a thermal-switch?..basically i want to get it working. and i know i could wire in a switch to do it manually ...but i dont want too
1984 Camaro 5.7L 350
700R4
Holley 650 Cfm
Edelbrock Performer Intake-Manifold
Crane Cams Duration @ .050": 204/214 Lift:420/442
Summit HEI Distributor
Hedman Shorty Headers
Hedman Y-pipe
Dynomax Turbo cat-back
NOS Decal
VTEC Decal
Old 06-10-2006, 06:06 PM
Re: Electric cooling fan
one other question where is the fan relay??
700R4
Holley 650 Cfm
Hedman Y-pipe
NOS Decal
VTEC Decal
Old 06-11-2006, 12:38 PM
guys....i cant drive this until this is fixed...anything would help? what tells the relay to turn the fan on?
700R4
Holley 650 Cfm
Hedman Y-pipe
NOS Decal
VTEC Decal
Old 06-11-2006, 03:19 PM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
The temp sensor
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
Old 06-11-2006, 03:37 PM
yes i know.....is the fan controlled by the computer at all?? and where is the relay?
700R4
Holley 650 Cfm
Hedman Y-pipe
NOS Decal
VTEC Decal
Old 06-11-2006, 05:53 PM
CamaroRS92 CamaroRS92 is offline
The fan relay is located on the firewall driver side (most of the time)
The ECM does not turn on the fan. There is a temp switch in the engine block on the right side just above the starter. Single green or green with white stripe wire. This is a ground that tells the relay to energize the fan circuit
Old 06-11-2006, 06:24 PM
with alot of looking i figured this out.........the pcm has a coolant sensor in the thermostat housing when that gets hot enough the pcm energises the relay which closes the circuit .. energising the fan..............i have a bad relay was my problem
700R4
Holley 650 Cfm
Hedman Y-pipe
NOS Decal
VTEC Decal
Old 06-12-2006, 09:59 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
I would put a a stand alone system in it and be done with it.
Old 06-12-2006, 06:08 PM
i thought of that...i havnt a clue where to find such a thing..
the computer knows a whole lot mroe than i thought it did....my dad put his scanner on it....and the computer knows the rpms.... coolant temp...vehicle speed tq converter status......alot of thing! i only pulled three trouble codes...im really amazed
700R4
Holley 650 Cfm
Hedman Y-pipe
NOS Decal
VTEC Decal
Old 06-13-2006, 09:16 AM
wrightz28's Avatar
There's a few of 'em out there, some either go to the block or to the radiator and are adjustable.
