Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 08-01-2002, 12:29 AM
Holyterror's Avatar
Holyterror Holyterror is offline
Coupe vs. Fastback
What are the main differences between S13 and S14 coupes and hatchbacks. Obviously, the fastback weighs a little more and probably has slightly better aerodynamics. Anybody got exact numbers? Anything else I should know?
"There are no substitutions for revolutions."
Member of AF's Slide Squad (Member #05)
Old 08-01-2002, 08:15 AM
SR20DETpower SR20DETpower is offline
Banned
Send a message via AIM to SR20DETpower
s14 weighs couple hundred more poounds. They both have 155hp KA24de I believe(91+) I personally like the S13 hatchback compared to the coupe, and over the S14 too. They are all good cars though and in the same neighborhood s13 weighs 2600-2800lbs I believe and the S14 is like 3k lbs or so, Im not 100% certain, NssnSpdr would know.
Old 08-01-2002, 10:36 PM
TatII TatII is offline
S13's weights 2700 when a S14 weights 2800. and the S15 becomes light like the S13 again
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 08-01-2002, 10:56 PM
94 Acura NSX
Best E.T. 13.559
Old 08-02-2002, 12:57 AM
NISSANSPDR's Avatar
NISSANSPDR NISSANSPDR is offline
Send a message via AIM to NISSANSPDR
Nissanspdr does know! HEHEHE
The S13 weighes 2600...coupe weighes a bit less than the hatchback due to all that weight of the window in the back...plus the coupe is more rigid which provides for a better autocross/road racing car.
The S14 weighes around 2750-2800 lbs.
For all out performance purposes...obviously the S13 Coupe would be great w/a SR or an RB or maybe even a KA-T.
For looks...it's up to a S14 or a S13 Hatch made into a 180SX. =D
Yours truly,
Gabriel
Old 08-03-2002, 10:23 PM
snoopafellajv's Avatar
snoopafellajv snoopafellajv is offline
Send a message via AIM to snoopafellajv
for looks i gotta go with the early 90s fastback
Old 08-07-2002, 05:48 PM
rockerdude rockerdude is offline
actually it's what you plan to use the car for, for straight path racing, a s13 is recommend for lighter weight, and for drifting it would be a 180sx because it has a better weight balance ratio of 50/50.
Old 08-07-2002, 06:24 PM
Fliquer Fliquer is offline
Send a message via AIM to Fliquer
They have nearly identical handling capabilities
Isitcontagious.com
'92 S13 coupe
KYB adjustable struts + Whiteline springs
Urethane bushings in all control arms and subframe
Cone Filter
Next up: LSD
RIP #05
