| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
WOOOO Good gas mileage finally!!
Yes...I did reset the trip when I filled up to full.
1995 GSX M/t 87k[IMG][IMG] Gotta lotta work to do. [IMG] [/IMG]
Re: WOOOO Good gas mileage finally!!
hmm... I am at 160 miles and I am at about the same spot as you are on the gas gauge. Does that trip include spirited driving or what?
95 GSX 5 speed 2.3L stroker bored .020 over Built head Bullseye/Borg Warner T04B 57 Trim Turbo RNR 3" turboback w/ o2 eliminator 255 lph Extreme Motorsports fuel pump Extreme Motorsports mbc SAFC Greddy Type S BOV FMIC (core 28x10.5x3.5) FIC 650cc fuel injectors RK Sport Fuel Pressure Regulator My Car Domain |
I am not going to lie..I did goose it once for a good accel... but besides that it was all very conservative without using the air conditioner
I get about the same as that but I dont have an egr, evap system, or any other emmisions. Do you have any problems with running rich or studdering or anything along those lines?
2004 Flame Red SRT-4 |Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd| Mods: ![]() |
Apparently I do run quite rich, and my car studders like a bitch at idle. It bumps along hardly at like 100 rpms or less....my air intake is messed up cause it is cheap and I can't afford a new one
BTW, your car would not run at 100 rpm. It would die.
'92 3000gt SL Zoom Stage 1 Clutch Quote:
OK MANNNNN chillax. I bought the NGK iridiums they came in on friday...but I thought I had the spark plug socket for them..and when i foudn out the palce was closed..and napa won't be open till monday so I can't do it till then.
p.s... it does idle down to 100..you nkow waht I mean..it's like.. pop....badop......pop....pop..
umm...I'm usually around 250 by then...
now - 2000 civic soon - 2002 is300
Make sure you gap them, they are not pre-gapped for your car. And be careful, those iridium tips are hard as hell to adjust and tend to break easily if you put a lot of pressure on them. They are also not meant to be gapped more than once.
Ah, I finally checked my gas milage today and I got a nifty 21.5mpg. Not bad for city/spirited driving.
You guys are checking mpg like this right?:
Just zero the odometer at the pump, fill it up, and when you fill up again (more miles traveled between these fill-ups will increase the accuracy) write down how many gallons the pump put in (it will say on the pump). Divide miles on the odometer by the gallons on the pump.
![]() '99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed) Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/ Adopt pets in need! http://www.petfinder.com/
Ya I asked my mom how to do that last night lol..even tho I guess there is only one way you could get a number that makes sense. You may be off a few decimals because the pump might not shut off at the exact same time each time...if you know what I mean.
JUST SO YALL KNOW I did put in the NGK BPR7ES plugs yesterday. Easy job.
What did you gap them at?
Ummm...well... the package said not to do it?? SO I didn't.. But the real reason why I didn't is because I don't know how..and even if I did know how..I wouldn't know what to gap them at..or even know how to tell how much gap there is.
I figured since that's what is supposed to be in the car..it won't to damage NOT to gap them.
