Old 06-10-2006, 10:27 AM
t_rappster t_rappster is offline
Leveling Kits?
I want to put 305/55R20's on my 01 chevy Z71 and didn't know if i should put on a leveling kit with adjustable keys, or put the leveling kit on with a 1" block in the back or extra leaf, or just get a 3" suspension lift. What do you think would be the best and what do you think of putting the block or leaf in the back with the leveling kit? The difference in cost between the leveling kit and suspension is about $1000 and I've had a body lift before and think they look bad, but i am not into the sky high trucks even though they look good, you just loose funcionability out of them.
Old 06-11-2006, 06:39 AM
silveradoHO silveradoHO is offline
Re: Leveling Kits?
I put a leveling kit on my 05 Z71 and like it a lot. It was real easy, about a half hour to put on. All a leveling kit is are new torsion bar keys, which allow for more adjustment of the torsion bars. I would suggest using the add-a-leaf in the rear.
Old 06-11-2006, 05:26 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
Re: Leveling Kits?
y do u wanna lift it, they will fit without doing this. i had a 305-45-22 on my truck with stock height in front and 2 inch drop in rear. pics in sig, and i have minimal rubbing in front but 20's should be shorter and not have then problem.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 06-12-2006, 05:27 PM
Re: Leveling Kits?
Did you put those on a 9" rim? That is what i was going to go with. I am coming up with the 305/55/20 to be 1/2" taller than the 305/45/22. but i would think it should clear with the lift.
Old 06-12-2006, 06:42 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Re: Leveling Kits?
305's will work on a 9" wide rim.
*Under Construction - New sig to debut*
Old 06-12-2006, 11:19 PM
PamzJoe PamzJoe is offline
Re: Leveling Kits?
Question, I have the leveling keys on my '05 Z71. If you go with the add-a-leaf block on the rear, do you have enough adjustment left on the bars to level it up with the rear?
Old 06-13-2006, 06:56 PM
Re: Leveling Kits?
I believe so. I had talked to a guy over the weekend and he recommended adding a leaf in the rear. but I still can't find out if I can fit 305/55/R20 on it though.
Old 06-13-2006, 11:15 PM
Re: Leveling Kits?
your problem will most likely be turning and hitting the inner fenders, lifting may help some but you will most likely need to modify the inner fenders to clear them.
