Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-10-2006, 10:20 AM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
i think i'm gonna join the 6 bolt club
well some of you know that i bent some valves, so it took my head to the shop and at first they told me they were gonna charge me arround 200 so i was like sweet, it's been 3 days and i didn't hear from them so i called them and they said" we've been trying to call you, you have some bent valves and you need to rebuilt the head, you are looking at arround 550!!!!" so i was thinking just go and buy me a 6 bolt, for like 1500? and they wanna charge me 60 bucks " for checking it out and tell me i had bent valves which i allready knew!!!!! so i think i'm just gonna let them keep my head and not pay them.
How hard is it to do the swap? what stuff would i need to modify?
any links to a write up?
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 06-10-2006, 11:55 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: i think i'm gonna join the 6 bolt club
Search and you shall find. Almost positive I read a couple detailed 6 bolt swaps on here.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 06-11-2006, 12:12 AM
kjewer1 kjewer1 is offline
AF - Advisor
I'm pretty sure my machinist does a full rebuild (new guides, valves as necessary, valve job, resurface, seals, clean, etc) for like 350. 550 sounds pretty unreasonable to me, and that says a lot because I don't mind spending money on certain things that are worthwhile (getting the head done right). I don't think letting them keep the head will work though, and they do have a right to charge you at the standard shop labor rate. Someone did have to work on the head, and they have to stay in business. Part of the risk we take by letting others work on the car/parts. 550 is absurd though.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
