Old 06-10-2006, 09:12 AM
xanarchistx xanarchistx is offline
Bad battery or bad alternator?
Hello everyone.
The problem that I am having is that I cannot tell if my vehicle is suffering from an alternator or a battery problem. I own a 01 GMC Jimmy 4.3.
What happened was this: As I was pulling out of a parking space, my battery light went on, and my car just stalled. The lights were still on, so I put the car into park, and then everything went out. I couldn't get my key out of the ignition, the lights wouldn't turn on, and I couldn't put the truck into any other gear. Then I got out, popped the hood, and put the support up. Once I did that, then the lights went back on. I went back into the car, put the key in the ignition, and attemped to turn the car on. The lights went on, the starter kicked, but the car wouldn't turn on. After a couple of minutes, the car then turned on, and I drove home.
I also checked this morning, and when I put my foot on the gas, the interior lights begin to flicker faster and faster. Also, there is a squeeking sound on he engine, probably coming from the alternator.
Now, what do you think could be the problem? Alternator or battery?
Also, I had the air conditioner on when this happened, so maybe that was a factor as well?
Any help would be greatly appreciated!
Old 06-10-2006, 10:20 AM
UncleBob UncleBob is offline
AF -Advisor
Re: Bad battery or bad alternator?
you might have 2 different problems. When the alternator light comes on on the dash, that is almost always a bad alternator.
But from your discription of lights flickering on and off, that could be either a bad connection at the battery terminals, or at the other end of the battery cables, or an internal break in the battery.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 06-10-2006, 10:27 AM
Alright. Well I dont know if my car has an alternator light, but I havent seen it. The battery light was on when this happened, even though it is a new battery.
Now, where should I lokk for the "other end of the battery cables", and what do you mean by an "internal break in the battery"? Im not really knowledgeable when it comes to cars.
Old 06-10-2006, 02:19 PM
AF -Advisor
the battery light is the alternator light. It comes on when the system senses no output from the alternator.
Old 06-10-2006, 02:29 PM
cody_e cody_e is offline
Send a message via AIM to cody_e Send a message via MSN to cody_e Send a message via Yahoo to cody_e
Also check the connectors from the alternator to the battery. If you have a multimeter you can check the voltages when revving the engine.
Old 06-14-2006, 07:54 PM
Gearhead202 Gearhead202 is offline
Or if you do not want to do this yourself bring it to a shop and ask them to perform a "load test on the battery" and if that comes back in check then have them do the same thing for the alternator. But make sure when they do the one on the alternator they turn on the High beams, rear defroster, and the air conditioning. So the maximum load on the alternator is being excerted then it should tell you.
