Old 06-09-2006, 10:41 PM
Flexin15r Flexin15r is offline
First post check it out
ok well i be looking around this site for a week or so, so ill register!
i took out my DRL (?) fuse so i dont have daytime running light, and i love it, so much better.
but now the fog lights dont work?
anyways my car is basically stock for now, except the stereo, i upgraded a bit.
anyways, what else can i do to my car?
im saving for a New Intake.
I do have a few problems with my car. My oil pan is leaking, and i really wanna fix that because it leaks kinda badly and realized im keeping my car till it dies, so im going to fix everything up.
Can anyone tell me are the oil pan gaskets a pain in the ass in my 3.8 motor?
thanks sry for the long post, i wanna gunna make it longer but fiqured id shut up
pics?
i needa get better pictures
-1998 Oldsmobile Intrigue -
-3800 series 2 motor -
Engine-
200 amp excessive amperage alternator
big 3new interstate battery
Stereo-
Headunit - Alpine Cda-9847
Sub - 15" Alpine Type R
Amplifier- Orion 2500D
Box - Custom TCAB @ 33hz
145+DB
What else can i do to it?
Old 06-10-2006, 12:28 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: First post check it out
since you have the 3.8 engine there is quite a bit you can do to that engine, im not sure exactly to what extent, but i do know that it has a sizeable aftermarket do to that engine being featured in the Grand Prix, Impala, and Monte Carlo as well as several other GM models.
Transmission wise i know there are a couple different shift kits available.
Basically anything suspension-wise made for the Grand Prix or any other W-body will work fine. There is a handling kit from GM Performance Parts that im considering ordering right now.
There are a couple different brake upgrades as well, you can either upgrade the stock rotors and pads....or upgrade to 12 inch rotors up front(stock is 11 inches unless you have the Autobahn package)...you can also get F-body calipers to work with 12 inch rotors, but im not sure if they will fit with stock Intrigue wheels...the Grand Prix owners say they will fit with stock GP wheels, but im not sure about ours.
some basic mods would be the intake of course, with a high flow cat and u-bend removal.
a better place for you to check out for modding would be http://www.clubgp.com because they have a lot more members with a bigger knowledge base, and your car is essentially a Grand Prix with a different shell on it...as is mine, but i have the 3.5 engine, so its a little different.
anyway, any questions lemme know, and definetely check out clubgp
Old 06-10-2006, 07:39 PM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
The 3.8 motors also have an issue with the rear crank seal / plate gasket. You may actually have to get the trans out to replace these seals. Have a good GM tech check this out. It could also be the intake gaskets or the pan gasket, like you said
