Old 06-09-2006, 08:49 PM
Tonyr's Avatar
Tonyr Tonyr is offline
EGR Valve trouble
My 98 GTP had the SES light come on and I had AZ check it out. It said there was an EGR problem. Is there a way to clean that out and where exactly is it? I changed my PCV valve a few months back but for some reason I don't remember seeing the black o-ring on the old one I tok out unless it is still in the slot and stayed in there while pulling the pcv valve out. If I am missing the o-ring, can I get one at a parts store??
Old 06-10-2006, 12:19 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: EGR Valve trouble
Both 3800 Series II NA and SC must have the black o-ring on the PCV valve. Without it you may get a P0401 DTC error code which means the EGR is failing flow test. See link below:
http://macgp.clubgp.com/howto/pcv/pcv.html
The EGR valve is located on the right hand side of the supercharger and throttle body. The black cylinder looking object with the electrical connector. It can be removed and the spring loaded pintle and other areas can be cleaned with carb cleaner. It may have lots of carbon. Make sure pintle moves freely. Then spray with WD40 before re-installing.
The o-ring is a common item and available at places like AZ. Good luck!
Timeslip 08/12/06
AF Community Guidelines
Old 06-10-2006, 12:23 PM
Tonyr's Avatar
I bought a new pcv valve and an o-ring from NAPA. After I replaced everything I started the car but the SES light was still on. Maybe I just need to get the EGR cleaned out. I was hoping it was just a bad PCV since I did not have the o-ring. It looks like the EGR valve is just behind the PCV Valve?? Any idea what it costs to get it cleaned?
Old 06-10-2006, 01:04 PM
BNaylor's Avatar
Whenever you get an EGR fault an odb-ii scanner must be used to reset the SES light and stored DTC error codes. Then run it to see if fault goes away after a few drive cycles.
The EGR valve is located in that area. Can't miss it. You can DIY clean it yourself for just the cost of STP carb cleaner. I do not know what an auto mechanic would charge since I do my own work. Good luck!
Timeslip 08/12/06
Old 06-14-2006, 08:20 PM
Tonyr's Avatar
I was going to pull the EGR off but noticed there is a gasket underneath. The EGR has never been replaced or cleaned to my knowledge ('98). I will probably need to buy a new gasket before I take it off and try and clean it???
Old 06-14-2006, 08:27 PM
BNaylor's Avatar
Yes, highly recommended to have a new one ready to go. But here is what happened to me. It came off intact and I re-used it. So I have this spare EGR gasket.
Timeslip 08/12/06
Old 06-14-2006, 10:07 PM
wlkjr's Avatar
wlkjr wlkjr is offline
I tried reusing one and it didn't work out for me. Cheap as they are, I'd have a new one handy. Cleaning the EGR is a pretty easy job. I'd get the Berryman B12 Carb and Injector cleaner.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 06-15-2006, 06:02 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I wish someone around here still carried that Berryman B-12, that was awesome stuff.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 06-15-2006, 06:15 AM
wlkjr's Avatar
Wal-Mart and Advance both have it here.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 06-15-2006, 12:42 PM
richtazz's Avatar
I'll have to check advance on my way home. I thought they discontinued it up here, but I hope I'm wrong.
