Old 06-09-2006, 08:04 PM
cavyowner cavyowner is offline
So Very Confused
Hey guys, im kinda confused as to what has happened with my car
i recently had four new tires put on my car, the exact same as the ones before it and now whenever i am driving along it squeals, i thought it might be the breaks but the only time it doesn't squel is when i am breaking .
hope someone can help me out with this
Old 06-10-2006, 11:09 AM
94VL 94VL is offline
Re: So Very Confused
Strange.If the tires were a different size or brand I would say they have a changed diameter or width and its effecting the toe in/toe out,because when you change the width of the "track" (as in wide track Pontiac) the tires operate in a different turning radius than before.
Old 06-10-2006, 11:10 AM
Maybe with so much tread on them (deep),they arent as good handlers as they were with "cut" (worn) treads.
Old 08-03-2006, 11:11 PM
dynastyperformance dynastyperformance is offline
to much tread
custom performance and audio
Old 08-04-2006, 01:01 AM
Young Chuck D's Avatar
Young Chuck D Young Chuck D is offline
Send a message via AIM to Young Chuck D
they'll be 'broken in' after about 200 miles..... or less if you stop and start hard
1999 Chevrolet Monte Carlo LS [semi-daily driver until LIM repair or trade-in for '13 Fusion, 110k miles]
Gone but not forgotten:
1995 Pontiac Grand Prix GTP[sold, 128k miles]
1996 Oldsmobile Cutlass Supreme SL Coupe [a minivan tore my door off, totaled, 84k miles]
1998 BMW M3 Hardtop Convertible [a pathfinder armada stopped in front of me, totaled, 70k miles]
1989 Chevrolet Cavalier Coupe [died, 160k miles, engine problems]
1990 Hyundai Excel GL [died, 220k miles, died]
Old 08-04-2006, 07:25 AM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
ive had this same problem, a constant squeaking pretty much, it stopped instantly when i went to use the brakes, and started back up after i let off the brakes, i replaced the front brake pads, even though the old ones looked practically new, they had at least 75% of their life left, but i replaced them anyways, and it hasnt squeaked since
try it out, its only $20, and if that doesnt fix it, then i guess you have new brakes, you lose nothing...
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 08-12-2006, 01:01 PM
Cold_Silence's Avatar
Cold_Silence Cold_Silence is offline
Send a message via AIM to Cold_Silence Send a message via MSN to Cold_Silence
Odd, try the brakes but it shudnt be. Just drive the tires for awhile and maybe it will settle down, when i did a rotation, my back ones were like brand new looking, and the fronts were pretty worn. When i swapped em up to the front it was louder cuz the more tread the louder it was, but its not a squeeling its more of a hum like the air whipping thru it.
Ah, maybe the lugs are undertorqued or overtorqued! Try that out, it could be pressed tight against the hub or loose and not running straight.
The New Ride!! 2002 Cavalier Coupe..
Originally Posted by noshun
It's a lovely 2200, but got about as much poke as my grandma with no fingers.
www.cleanstartsolutions.com
Old 08-13-2006, 10:01 AM
Blue Bowtie's Avatar
Registered Offender
That's a good indication of an alignment problem. You can ignore it and keep wearing out tires prematurely (and wasting fuel) or repair it now. The old tires were likely feathered to match the misalignment and the new tires are trying to roll straight along, and are audibly complaining about being pushed down the road at an unnatural angle.
Old 08-13-2006, 11:33 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
As Blue Bowtie says
Get a good front and rear wheel alignment Like a good 4 wheel alignment job.
The people that sold you and installed the tires should have told you that.
Unless the want to keep on selling you tires ever 5-10k miles.
MT
MT
