Old 06-09-2006, 07:57 PM
bigdaddy12003 bigdaddy12003 is offline
Send a message via Yahoo to bigdaddy12003
Question Failed e-test
I just recently purchased a 95 ga with a 3.1L sfi. I took it in for an etest and it failed. the results where high NO, and the pamphlet said egr inoperative/defective, lean air/fuel mixture, and inoperative catalatic converter (3 way catalyst only) So i got the egr valve replaced for $328 and i am just wondering if anyone else has had the same issue. I need to get it plated. thanks to all those who reply. And i must mention that the old egr valve has 3 solenoids and 2 solenoids had problem and was wondering if thats the full problem.
Old 06-09-2006, 08:41 PM
maxwedge maxwedge is offline
A990 racer
Lightbulb Re: Failed e-test
Blocked egr passages could be an issue also, manually powering up ( grounding the solenoids) should cause the engine to stumble or even stall when the egr is fully actuated, if not there are additional problems. Have you retested it yet?
Old 06-10-2006, 08:11 AM
Re: Failed e-test
I have replaced the egr valve and was just wondering if there are any other issues i could try. My car is going in for an etest this week. Thanks for your reply. I am hoping its good to go cause i just put a new one one so i will have to see.ty.
Old 06-10-2006, 10:58 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Failed e-test
Remove the EGR again and clean the passages to the engine. They will clog and cause the same problems as if the egr was not functioning. I would do this before trying again. Simply use throttle body cleaner to clean the carbon out of these passages. I removed the phlenum on one I cleaned and sprayed the entire phlenum to get the carbon out. A gun brush will also help to clean these passageways if you don't want to remove the top end. Good Luck!
