Old 06-09-2006, 04:45 PM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
Alpine Renault A442B - mostly not OOB
Hi guys: lot of time since I do something in that section: happy to be here
Well this would be a kind of exercise: I'm trying a whole different workflow: I put apart our pricey hobby stuff to try something new: pro industrial stuff like acrylics primers, flat base and 2 part clearcoat, so don't expect miracles from me, as you'll know shortly I found out some troubles but also a lot of fun and.. at least I know something new.
So far the subject: nothing special to me: I discover it in a LHS and I token it for the price and due to the awesome livery, by and by I become to love it and discover the hystory of this little beast driven by the "Little Prince of Speed" Didier Pironi: I ever loved him albeit my preferred at that time was Jacques (and obviously Nelson: who haven't loved Piquet?). This car beated awesome Porsche 936 and won the 1978 LM.
Well I won't to bore someone so quicly to the built:
This model is like a motorized car, so lack of inside details, also is a bit like a snap-mount in few points: I tried to remove those "toy" appeal point: I had close those block-holes with styrene and putty.
I also deepened air-intakes by cutting edges and creating some styrene walls, and drilled holes in the door
Front air-scoop was closed and really thick: I cut out all and redo with styrene strips, than I done the front scoop cover, like in the real car
A bit of thinned putty and those was decent to me
I tought a bit before a decision on the rear intakes: than I done the same than for the front scoop:
Was really hard do a decent putty job on the snorkel base: really close room to sand out putty, I used also on here thinned putty to minimize sanding, in light layers
I also removed fuel caps to redone some alu turned stuff and.. disaster in the left side the mill machine (I used it with the body free in the 2-axis table) do its sign on my body shell: another putty job just over panel lines!
Headlight have a internal surface to fix plexiglass cover so I done it by styrene: before I drawn the evenlop like when you do a CF job
I redone panel lines withe the help of a "DYMO" tape, the back of the cutter, and a scriber.
gio
Old 06-09-2006, 05:07 PM
gionc's Avatar
Authorized Vendor
Re: Alpine Renault A442B - mostly OOB
Quickly to the new products: basically one reason is i'm bored to spend 30-40 eur every car in Tamiya cans, also I'ld try something better (or supposed better)
So after sanded all the body shell I used as primer and sealer (next step hot paints) an acrylic grey base from Lecher, after that I used a white acrilic to lighten the tone before spray the yellow. I found out those quetly hard to flush out from the airbrush (Iwata HPCS, 0.3 diam.) but the finish is superb and this kind of color is a bit "progressive" and hard compared to Tamy stuff to me, not easy so sand down until the plastic
I done this job in 4 or 5 step, every layer wetsanded
Cyan circle just to note that I sand down the front splitter to a better "real " appeal
So was the time for the yellow flat base: it's a mixed "Ferrari Giallo Modena" from Lecher, I found out this and teh PPG "rosso scuderia" really awesome: almost the best thing I flush over my AB, I done the job in just 2 steps, wetsanding after each layer
This flat base is really quick to cure: the day after spraying I start the decal's job: I had to use a lot of 'set and 'sol to put down those giant decals! Lettering are joined with coloured areas so.. no chance for a 2 tone sprayed livery.
I had my first trouble with the first clearcoat: may be I had some few sol and set particles and the clear react with, the surface was realli like an emmenthan chhes with some friends help (Thanks guys ) I fix the problem cleaning with alchol the surface before spraying. So I sanded down, destroyed some few decal, touch up, and finally a couple of wetcoats w/out big difficoulties: that's the result, soon with polishing and few interior details and.. Didier figure
Thanks in advance guys for reading and for your kind comment
ciao
giovanni
gio
Old 06-09-2006, 06:01 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Nice work, Gio! Looks teriffic. I've been wondering when you'd start this one. Your detailing touches to the air vents add alot. Another cool esoteric build to follow!
PHOTOBUCKET SUCKS
Old 06-09-2006, 06:05 PM
freakray freakray is offline
AF Modelrater
Excellent work Gio, those vents look brilliant after you redid them
AF User Guidelines
Old 06-09-2006, 08:08 PM
quadzero's Avatar
quadzero quadzero is offline
excellent body work and modifications. I find them very hard to do but you make it seem like a breeze. great livery.
Old 06-10-2006, 12:51 AM
sportracer02's Avatar
Hi,
inspite of "mostly OOB" you did some significant improvements.
Looks very nice !!!
Micha
Old 06-10-2006, 02:28 AM
klutz_100's Avatar
I cant see the pics
But its awsome anyway
I have just one word for you, Gio - CHINA!
Very interesting ino on the pro paints. I would like to try that sometime. I'm trying to get some modelcolorworx paints but I guess my emails keep getting lost
Old 06-10-2006, 02:46 AM
robrex's Avatar
robrex robrex is offline
that is looking really nice!
Rob
Old 06-10-2006, 03:15 AM
gionc's Avatar
Authorized Vendor
Thanks thant thank thanks a lot guys: a bit of support (&ego massage) work well on this damn project not my usual stuff
Les> from what I seen on your "406mph.." few modifications wan't worry you a bit, thanks and congrats for those huge&fun project
Steve> China project is 85% done: like you heard last sunday I found out a great source for those fuc###g dragon just prime you scangi that dragon'll fly to varsavia soon (with some few other abarth crap )
Well I taken a shoot outside before polishing it: maybe it could be worst after my "touch"
gio
Old 06-10-2006, 04:00 AM
stevenoble's Avatar
Excellent finish.Looks superb.
Steve Noble
Old 06-10-2006, 04:51 AM
RandyPng's Avatar
RandyPng RandyPng is offline
Another masterpiece in the making!!
Current Project:
Calsonic Skyline GT-R (R34) - The older one
http://www.automotiveforums.com/vbulletin/showthread.php?t=533891
Old 06-10-2006, 05:29 AM
godfather23's Avatar
godfather23 godfather23 is offline
Originally Posted by gionc
Is it just me or do you have big hands??? Joking aside, the work you´ve done, looks great. I´m looking forward to see the rest of the build!
Keep it up!
Recently finished Projects:
Porsche 911 Carrera RS 3.0
Current Projects:
Old 06-10-2006, 05:43 AM
DasWiesel's Avatar
DasWiesel DasWiesel is offline
I have to agree, this truely is an awesome livery and you made a flawless job on the body!
Is this one of the older Tamiya kits?
Julian
Old 06-10-2006, 06:10 AM
klutz_100's Avatar
Now I can see teh pics - and Like I thought, it looks awsome
And uff, what a great livery!!
You NEED to polish it?!?!? The shine looks excelent to me......
Old 06-10-2006, 10:52 AM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
Very Tidy work
Steve a.k.a. Hiroboy
