Old 06-09-2006, 03:59 PM
thebigbr thebigbr is offline
heater motor...
ok, so i have no blower motor....i hear the buzzing of the motor wanting to turn but its not...so i go out and get a new motor replace it, now it wont turn at all...i check the fuses..all ok...check the fuse box under the dash for power with a multimeter..no power at that terminal, check the connection to the motor...no power....i dont know whats going on, maybe the switch on the console is burn out?...i dunno!
any ideas?
Old 06-09-2006, 10:05 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: heater motor...
Check and see if there is power to the switch, the switch just varies the resistance to the motor, so if it has powr before that youve found it..
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 06-09-2006, 10:31 PM
Re: heater motor...
i checked the fuse box for power and non at the blower motor terminal....does the power supply cequence go:
switch-fuse-motor?
or
fuse-switch-motor?
thanks
Old 06-10-2006, 02:44 PM
FrodoGT's Avatar
Re: heater motor...
From the battery it runs, Ignition switch/no. 19 fuse/motor/fan switch on the ground side..
Current project:
Rio Red 91 hatch.
