Old 06-09-2006, 02:23 PM
RickwithaTbird's Avatar
RickwithaTbird RickwithaTbird is offline
Send a message via AIM to RickwithaTbird Send a message via MSN to RickwithaTbird Send a message via Yahoo to RickwithaTbird
quick question
if an amp is rated at 75w x 4 RMS,
how many watts would that produce at 2 channels 2 Ohms?
300W x 2 RMS @ 2 Ohm??
R.I.P.: My Thunderbird "Ricks 96".. 2/08/96 - 1/14/05.
Old 06-09-2006, 07:39 PM
BlasZ24 BlasZ24 is offline
Re: quick question
I would think more like 200-250W RMS.
Old 06-09-2006, 08:19 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: quick question
Well it would have to be 1ohm stereo stable, but anywhere between 150 and 600 x 2
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 06-10-2006, 10:30 AM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: quick question
SR20, still havent sold that e12a or just havent changed your siggy?
my e12a is fixing to go through a transformation.
Old 06-12-2006, 10:36 AM
Re: quick question
this is one thing I never really understood. How do you calculate wattage when you bridge an amp? Other than just what the box says.
I don't understand why the amp would have to be 1ohm stereo stable.
Old 06-12-2006, 12:34 PM
bjboertje's Avatar
bjboertje bjboertje is offline
Re: quick question
because each channel of the amp will only be seing a 1 ohm load when the total resistance is 2 ohms.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 06-12-2006, 05:57 PM
sr20de4evr's Avatar
Re: quick question
Say an amp does 25x2 @ 4ohm and 50x2 @ 2ohm. That amp would have to put out sqrt(25*4)=10Vrms per channel before clipping to pull that off. If it's only 2ohm stereo stable, then the maximum current the amp can support is 10/2=5 amps. When you bridge, the voltage from the L and R channels add together, so your bridged channel is putting out 20Vrms. If it's putting out 20V, and can only support 5 amps, then the minimum impedance it can safely run at when bridged is 20/5=4ohm.
'01 Black Sentra SE
'05 Silver WRX STi
Old 06-13-2006, 02:54 PM
Re: quick question
that was really hard to understand, but I get it. I never would have figured that out myself. Thanks.
