Old 06-09-2006, 12:28 PM
wolter wolter is offline
2002 Silverado LS - removing bulbs
The daytime running lamp bulb is burned out, on my driver's side. I bought some new bulbs, but at first glance, I don't see how the bulb is accessed. Can anyone help? Thanks!
Old 06-09-2006, 02:07 PM
guumbah's Avatar
guumbah guumbah is offline
Re: 2002 Silverado LS - removing bulbs
There should be some retaining rods and/or clips on top that allow you to swing out the lamp assemblies when disengaged.
2002 5.3l - Quadrasteer
lose (lüz): v - to suffer deprivation of : part with especially in an unforeseen or accidental manner
loose (lüs): adj - not rigidly fastened or securely attached
Old 06-11-2006, 02:46 PM
chuck16's Avatar
chuck16 chuck16 is offline
Are you getting the fixture out? You have to take the Headlight out to get to the clearance lights.
Can't remember which side of the assembly it is but, you'll see a clip that holds the fixture in. Squeeze it and the lower fixture, DRL/Signal assy, should pop out.
Turn and unlock the drl Light holder.
The bulb itself has little clips on it. I tried mine for the first time pulling like hell and couldn't get them out. So, I used 2 blade screw drivers on each side of the bulb and popped it out. (Obviously not the glass part of the bulb)
Clear as mudd?
Let me know if you need further clarifiction...
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
