| View Poll Results: Stang Question | |||
| help me out please |
2 | 40.00% |
| reply if any ideas...thanks |
3 | 60.00% |
| Voters: 5. You may not vote on this poll | |||
I have a 1999 stang that has recently been making a rattling noise from the front passenger side of the car. It makes a little rattling noise down by the tire/engine when the car gets near the 800-1000 rpm range. Can anyone help me out and give suggestions as to what is wrong...thank you.
Well all I can tell you is go have it checked out by a shop or somthing.
Does it sound more like motor or suspension?
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world has lost one of the truly wonderful people...
Do you have to be moving? or is it just related to engine speed?
More photos and Info/website! 1994 Cobra -off road h-pipe -superchips power chips -mac cold air induction -BBK aluminum underdrive pullies -pro-m 75mm bullet MAF -18" konig wheels with nitto 555 zr tires -Ford Racing 65mm throttlebody -Ford Racing king cobra clutch -Ford Racing 3:73 Gears -Ford Racing Aluminum driveshaft -Bullit suspension/ springs,shocks,struts -Aubrun HD limited slip Diff. 2002 subaru Impreza RS - stock 1989 Toyota pickup 4x4 -K&N
That's what I meant SVT better phrasing
Kinda curious...did this need a poll?
Alan
I think it is pretty obvious this post having a poll is just absolutely needed
Rattles and noises are the hardest things to figure out when you can't hear them.
Now when did this start happening? Have you changed anything on the car? Have you hit anything recently? What were you doing when you first started hearing this noise? Any other info you can give us would help greatly in determining the source of the problem.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex -1999 Ford F150 |
TRUST ME------I've got the answer and it ain't good
next time---when you start the car. Let it idle for about a 5 minutes. Then rev it a few times. If you hear a rattle. Thats most definetely your engine knocking-------and bro------thats also the sound of having to get a new engine. I'm all too familiar with that sound. You can also check that rattle after drive for a while. Just pull over----sit in idle and a few pushes of the pedal and listen. Any suspension problems just won't rattle like that when sitting in idle. And I'd cast serious doubt that a header isn't properly installed-------because those things come fully bolted from the factory. And if the exhaust is loose-----it will rattle every time---right from the get go---when you give it gas! Good luck dude-------but it sure sounds like engine knock.
"If you want to outrun a Viper, just slap a blower on a Cobra and rebuild the rear end" 2001 mustang cobra convertibe Vortech V-2 SQ blower (10.5psi) 4:10 gears & ford racing throttle body 03 JBA shorty headers + FR500 exhaust Bassani X-pipe Kenny Brown IRS level 2 suspension IRS pinion brace Kenny Brown K-member & control arms Carbon Fiber driveshaft 522RWHP / 493RWTQ |
