Old 06-09-2006, 10:54 AM
98 Lunima LTZ 98 Lunima LTZ is offline
Question 98 LTZ A/C issue
I have a 98 LTZ and it has the dual climate control (drive passenger) hot cold. When the A/C is on and the two switches are in 'COLD" the passenger side is still hot????? but the drivers side is "COLD".
Also, I'm in AZ and its a black car to boot can you say HOT! Any how the A/C seams to cool better when idle at a light then when driving down the road????? I have checked to make sure the belt is not slipping on the compressor, seams to be tight...
Anyhow, ANY HELP WOULD BE MUCH appreciated!!!!!!!!
Old 06-09-2006, 11:15 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 98 LTZ A/C issue
It's probably a bad temp actuator for the passenger side. On dual climate control systems, there is one for each side. It's possible the refrigerant is low, but that will usually cause the passenger side to be cooler than the driver side due to the way the evap core is situated.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 06-09-2006, 11:42 AM
Can you tell me where the actuator is located? is it $$$$, easy to install? or will I have to recharge the sys?
Thanks for your HELP!!!
Old 06-09-2006, 12:10 PM
richtazz's Avatar
If it's the actuator, it is mounted high under the dash near the center console. It is held on by 3 screws and is operated electrically. If you can get your hand on it, as you move the temp switch, you should be able to feel it operating. Changing it will not require you to re-charge the A/C if the actuator is the issue. You'll only have to charge the A/C if the refrigerant is low. The AC-Delco part number is 15-71846, and it costs $65 at the dealer. IF you have a Delco parts store near you , trade price is $45.50.
