Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 06-09-2006, 06:51 AM
udfxrookie udfxrookie is offline
Digital read on compass says OC
On my digital compass it says OC where the temp. should be and then it shows direction... why doesn't it show the temp... sometimes it does, other times it just goes back to 'OC'
Old 06-09-2006, 06:22 PM
goser goser is offline
Re: Digital read on compass says OC
Check the owner's manual. I was driving along once and something popped up there, so my passenger checked the manual and told me i had to drive in a circle three times to recalibrate the compass. I thought she was pulling my leg until I pulled over and checked it myself...
Old 06-09-2006, 08:29 PM
I tried that because that's what I thought it was but it isn't that... that would say something different...
Old 06-09-2006, 08:59 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
It's broke then. OC means it needs to be calibrated but if it suddenly shows it now without messing with it, it's broken.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 06-10-2006, 07:17 AM
It show direction, this is the temp. part, not the compass...
On the digital readout it shows temp then compass right next to it. It's always shown the direction... but the temp shows in the mornings when I start my car and after a while it changes back to OC....
Old 06-11-2006, 08:44 PM
Any other ideas guys?
Old 06-12-2006, 12:16 AM
thadrawr's Avatar
thadrawr thadrawr is offline
Send a message via AIM to thadrawr
Its gone man....mine says C also or it tells me it is 150. Its not worth the time or money to fix it.
1999 GMC Sierra 1500
Old 06-12-2006, 08:47 PM
The only thing you could try is to just order the sensor itself or check that the plug isn't corroded. Usually the sensor with a small plug is under $25 from the dealer.
Pioneer 4900mp
Orion C63 Coax rear
Old 07-17-2006, 12:32 PM
95ragtop 95ragtop is offline
OC means Open Circuit. The wires or temperature probe has an open somewhere. Also, SC means Short Circuit on the temperature wire/probe. You can unplug the probe (behind the grill) and put a short across the connector. If the display reads SC, its the probe. If it still reads OC, its the wires. Easy fix when you know what to look for.
Old 07-18-2006, 09:30 AM
That's a great tip. I just found out about that too to help find a problem with a customer's mirror I installed. It ended up being the main harness connector on the back of the mirror itself.
Pioneer 4900mp
Orion C63 Coax rear
Old 07-18-2006, 11:23 AM
95GMCJimmySLE 95GMCJimmySLE is offline
my girls 93 Jimmy also reads OC on the temp. How do I test if it's the wires or the sensor? Where is the sensor even located?
1995 GMC Jimmy SLE w/ 4.3L VORTEC
Old 07-21-2006, 10:01 PM
It's in the front grill. It's black so you'll have to look for it carefully. It will have 2 wires inside one plug. Take out the sensor and use a paper clip into the 2 wires in the car and see if the display changes.
Pioneer 4900mp
Orion C63 Coax rear
Old 07-24-2006, 08:42 AM
ok, I'll give that a try.
I assume if the display changes then it's not a break in the wires and it's a bad sensor? Any idea of what the display should change to? Or is any change what I'm looking for?
Thanks
Old 07-26-2006, 10:43 AM
the change is what you want to see. If it changes, the sensor is bad. If it doesn't you have something else wrong.
Pioneer 4900mp
Orion C63 Coax rear
