Go Back   Automotive Forums Car Chat > Saturn > Ion
Old 06-08-2006, 07:44 PM
Markings Markings is offline
Revn Limit-Please advise
I am a total car neophyte and I went in today to go look at a 2005 Saturn Ion 2 (automatic). Everything seemed fine during the test drive but then I revved it up at neutral and at 4000 rpm's the engine shut down.
Now I have been researching rev limiter on the internet and it seems that the Saturn has a rev limit at neutral of about 4000 rpm's.
However, my questions is that once the rev limit is reached will the needle not go past 4000 or will the engine shut down completely. This cars engine shut down completely and I want make sure that it is a design specification and not an engine problem.
I appreciate any feedback as I plan to buy this ASAP. Thanks.
Old 06-08-2006, 07:46 PM
Re: Revn Limit-Please advise
Also, just wanted to add that I tried to rev up a Saturn L-3. And although it was also limited at 4000 rpm's the engine did not shut down completely- as opposed to the Ion 2.
Why?
Old 06-15-2006, 09:44 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
the S-seires was limited to 4K when the VSS read 0mph, i'm not sure what other models are limited to but its in the same ball park.
when the rev or top speed limiter is reached the PCM will cut fuel injection until the rpms drop below the limiter, which then fuel is again injected, until the limiter is exceded again, and the cycle contunes until you get your foot off the gas, which if you done you know it is very jerky. the rev limiter is designed to prevent engine damage by over reving with no load by fools that don't know better, not that holding it at 4K is that smart ether....
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
