Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 06-08-2006, 05:59 PM
reggiestewart reggiestewart is offline
lots of e30 parts
good running 2.5 L "i" motor. Removed from wrecked (rear end) '89 325i w/ 170K. Just cleaned and painted. new timing belt, tensioner, water pump, oil seals, valve cover gasket, and oil pan gasket. It has the newer style torx head bolts already installed.
3.73 LSD
5-speed swap kit
Various other parts from three '89 "i" cars, and one '85 "e".
Old 06-15-2006, 01:42 AM
daddyo8 daddyo8 is offline
Re: lots of e30 parts
Reggie,
How much are you needing for the engine? Is this the same one that's in the 93 325i? I always like to have a spare in the garage just in case.
Old 06-15-2006, 06:37 AM
Unless you have a convertible, I doubt it is the same.
in '92 BMW revamped their 3-series to the "e36" bodystyle, and at that time they went from the SOHC 2.5L M20 engine to the DOHC 2.5L M50.
They did run the e30 bodied convertible with an M20 engine into '93.
So, is your car a convertible?
Old 06-19-2006, 08:11 PM
mdmaz17 mdmaz17 is offline
I just had my timing belt/chain go on my 92 e30 convertable. what would you like for the enging / or just the head assembly?
Old 06-19-2006, 09:16 PM
Smile Re: lots of e30 parts
850 obo for the longblock assembly (head and bottom end with all of the new parts mentioned above already installed)
I can e-mail you photos if you wish.
Old 06-20-2006, 04:11 AM
I would like to get some pix. I will also cross reference the part #. Where are you located? I will get an offer to you if I find it to be a good match. Mark
Old 06-20-2006, 06:21 AM
I sent you an e-mail through the forum. I'll need your actual e-mail address to send photos.
I'm in Indiana.
It looks like you're in NY, so I'll work on a freight quote.
Thanks!
Old 06-20-2006, 12:44 PM
Depending on whether you want the engine shipped to your home, business, or a terminal, I can get it to your zip code in NY for $250-$300.
I just put the engine on eBay, so you can see photos here:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=8077317336
Old 06-20-2006, 07:26 PM
It looks good. Where in Indiana are you I may like to take a drive. If you would let me in on the reserve price I may be able to talk my wife into it. Mark
