Old 06-08-2006, 04:11 PM
rthomson rthomson is offline
Code 35 and Fan is always running
I have a 94 Caravan which has a code 35 - Open or shorted condition detected in the radiator fan low speed relay circuit. When I key the ignition the fan comes on? I don't even start the engine. I found that if I disconnect the Low Pressure AC pressure switch the fan shuts off. Remember I have not even started the engine! I have replaced the AC pressure switch which did not fix the problem. Is the fan suppose to come on before the engine is started? My belief is the fan should only come when the water temp is high enough and/or the AC is on while the engine is RUNNING! I pulled and tested all the relays in the power distribution box which all tested OK. If someone here has experience with this problem please post possible solutions.
Thanks,
Rich
1994 Dodge Caravan CV
3.3L engine 95k miles
4 speed auto Rebuilt @ 75k
Old 06-08-2006, 08:26 PM
KManiac's Avatar
KManiac KManiac is offline
Re: Code 35 and Fan is always running
Sounds to me like you need a new radiator fan relay. Now, if your 1994 van is anything like my 1998 van, the radiator fan relay is NOT in the relay box. It is bolted to the radiator support somewhere near the radiator. Search this forum for my post on this subject. If the 1994 van is different from the 1998 van with respect to the radiator fan relay, I hope someone else out there can direct you as to where to find this relay.
Good Luck and let us know what you find.
"This car may be old, but it will still climb Kirker Pass at 110!"
1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible
Old 06-09-2006, 09:32 AM
I have a new Radiator Fan (1 month old)
1996 Model year was a redesign year which changed many systems on the Dodge/Chrysler minivans. 94-95 Minivans were interchangable. The 94-95 uses relays in the fuse box under the hood to control fan operation. I have switched the relays and it did nothing to fix the code 35.
Rich
Old 06-09-2006, 10:38 AM
KManiac's Avatar
Well, if the fan is brand new and you know for sure the relay is good, then the only other place to look is the wiring. Insulation can crack and connections can separate or come loose. Time to get out the ohm-meter and do some troubleshooting.
I am not that experienced with the 1995 and earlier vans. Once had a 1989 Grand Caravan until we bought the 1998. I sure wish I had that van back. It has much more legroom in the driver's seat then the 1996 and newer vans. At 6'-4", I will take the legroom over the turning radius any day. But the van is my wife's car, so I get overruled.
Good luck and let us know what you find.
Old 06-09-2006, 01:33 PM
Thanks, I had hoped it was a common problem. I was going to check the wiring but do not have any shop manuals.
Thanks to ebay....
Chrysler 1993-94 Dodge Plymouth Body Diagnostic Manual
Chrysler 1994 Dodge Plymouth CCD BUS Diagnostic Manual
Chrysler 1993-94 DodgePlymouth 3.3/3.8L Powertrain Diag
Dodge 1994 Caravan Town & Country Voyager Repair Manual
All for $100
I don't mind getting my hands dirty but I need manuals to guide me through the diag procedures.
Old 06-09-2006, 10:46 PM
rrclyoung's Avatar
rrclyoung rrclyoung is offline
This is a problem that I chased for several years in my 94'.. I would get some time...look into it, get frustrated and then move on. I finally noticed that if I disconnected the sensor in the A/C line, to the left of the radiator, the fan would shut off, this is the sensor that turns the fan to high if the R134 temp is to high coming out of the condenser. I replaced that switch and the fan problem was gone and it cycled properly like it should. The switch is on a schrader valve (like a bicycle tire) and will not leak coolant when removed, I can't remember right off the top of my head but I believe the switch was about $30.00......hope this is your problem.......good luck
Chuck Young
2006 Chrysler T&C Touring 3.8
2005 Chevy Trailblazer LS 4.2 I6
2004 F150 Heritage
2007 Mitsubishi Endeavor
2008 Pontiac G6
Old 06-10-2006, 02:59 AM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Code 35...Radiator fan relay An open or shorted condition detected in the high or low speed radiator fan relay circuit.
Test the A/C Pressure switch for continuity. This switch, according to the wiring diagram is normally OPEN...if yours is closed it will provide a ground path for the relay/s and turn the fan on right away. It appears that you are getting a ground shot from somewhere that you shouldnt have.
You say that with the switch disconnected the fan stops...have you waited a bit(for coolant temp to rise) to see if the fan kicks on normally with the pressure switch disconnected?
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
