Pilot tube ? for David
Dude,
Did someone say it would not work for your engine? If so, why? I do not see why it would not work.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
Re: Pilot tube ? for David
It would work if I needed the extra fuel with smaller more street friendly jets. But Kevin sent me 67/82 jets in my CSU carb. It is meant more for turbo motors, but could work on a blower motor. It has not been tested yet with a blower motor that I know of. All it does is give the bowls a better pressure signal to push more fuel thrue less jet. So in theory it would work with a blower motor as well. I dont think I will need them though.
1969 Cougar 357w & TKO - 475hp |
67/82, that is not that bad at all. At least its good to know if we run into a rich cruising mix, you could always try to jet down a little with that mod. With yours running 67, like you said you should be OK.
You wouldn't happen to have any 2" exhaust pipe around? I need a 4" piece for my wastegate.
Let me check & I'll get back to you. I cant remember if it was 1-3/4" or 2" that I used for my Mondo bypass valve.
Sorry Tony, no 2" pipe.
