Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-08-2006, 12:36 PM
LuxAeternaDT LuxAeternaDT is offline
Hissing from passenger side
Hey everyone, I am new to the forum. I have a 1999 Isuzu Rodeo LS 4WD. Just have K&N Drop in and 35% tint. Recently when running the A/C or the defroster I am having a fairly loud hissing noise coming from the passenger side dash. Is my A/C compressor shot, or could this possibly just be a leak? Defroster still works since I was using it yesterday. Sorry if this has been asked before in the forum, and thanks in advance for your responses.
- Jared
Old 06-08-2006, 01:15 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Re: Hissing from passenger side
You are probably just hearing the refrigerant going through the expansion valve. They can be a bit noisey sometimes. You might check your refrigerant charge to see if its low, they will make more noise if it is.
After running the engine with a/c on for a while, let it idle and check the site glass on top of the reciver. It is between the grill and radiator support to the drivers side of the radiator. If it has bubbles (looks white) while idling and on full cool then its low. If its clear then it should be a full charge.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 06-09-2006, 08:22 AM
Ok I checked it out, and its still making the hissing noise fairly loud. I ran the engine with the A/C on for roughly 10 minutes on speed 1 full cold. The air conditioning is very cold but still have the hissing noise, I was looking where I thought you pointed out for bubbles, and did not see any. I can't figure out what the problem is, but lets say it is low charge, what would I go about doing then?
