Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 06-08-2006, 10:07 AM
orangel orangel is offline
Help to Test, maintenance or replace Sunfre 2002 Sensor's
Hi
I have a sunfire 2002 2.2L and I observed an important diminution in the gasoline yield and power, the use and routes are such, I changed all filters (gas, air) and the condition is same, the car have 55000Km.
1.- it wanted to know if he is recommendable resete or to reinitiate the computer to its original values.
2.- exists some form to give maintenance to the sensors for this model? , some form to verify its correct operation without the scanner? , some Link where can find diagram of the location the different sensors and their use for this model?.
3.- Some form to correct the gas mix.
4.- Tips to correct the problem.
Old 06-08-2006, 10:34 AM
hotbug1776's Avatar
hotbug1776 hotbug1776 is offline
Re: Help to Test, maintenance or replace Sunfre 2002 Sensor's
Get a Haynes manual for your car, it tells you all you need to know about the car.
http://www.haynes.com/na101.html#anchor561259
book #38016
