Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 06-08-2006, 06:05 AM
GTRider0 GTRider0 is offline
Send a message via AIM to GTRider0 Send a message via Yahoo to GTRider0
Question Hole in firewall
I have a 2006 focus 3 door and i want to put a system in it and i want to wire it right and i can't find the hole in the firewall that i can put the amp wire through, if anyone can help me that would be great thank you
Old 06-08-2006, 11:15 AM
shizznizz980 shizznizz980 is offline
Send a message via AIM to shizznizz980
Re: Hole in firewall
I did'nt have to make a hole for mine. Ok so you have to lift up your air intake so it will be easier to see the entrance I'm talking about, then you have to unclip the fusebox thats against the firewall after you've done all this you look down and theirs going to be a oval shaped black plastic thing so once you've spotted it go inside your car and lift up the carpet thats against the firewall and after you lifted it up there you will see the screw for the plastic thing or the nut might be on the other side I don't remember
hope this helps
