Old 06-07-2006, 11:25 PM
Kyle Brown Kyle Brown is offline
Unhappy A/C Turns off and on (SOLVED!!!)
I have yet to find anyone with this problem! My 2002 TB has started acting possessed in the past month. My A/C spontaneously turns on (climate control panel turns off). Then 5 seconds later turns back on. This happens over and over for about 15 min then stops for the rest of the day. When the power turns off the a/c of course turns off too. Another wired thing it started doing at the some time is it will spontaneously change radio stations. Has anyone else run across this problem?
Old 06-13-2006, 09:02 AM
Re: A/C Turns off and on
Maybe I'm just the only one has has it. Yesterday I checked all fuses grounds, relays, and connections. I've read the chelton book over and over. I've check the PCM and DIC they seem to be connected, well all fuses ok. I live in Texas, yesterday it was 99 degrees and I have a 2 y/o in the back (HOT!!!). Dose anyone think I should by PCM program reade (that my help) or would it be a wast of money.
Old 06-13-2006, 09:52 AM
rodeo02 rodeo02 is offline
No clue on this one! If all the connections behind the dash look good, maybe a body control module problem? Not sure if the A/C and radio are tied into the BCM.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 06-18-2006, 11:07 AM
I Fixed it!!! After taking the dash completely apart. It was the BLUE pin connection into the HVAC control. The orange power pin was oxidized. TEXAS HEAT BRING IT ON!!!
