Old 06-07-2006, 09:37 PM
stockups stockups is offline
1994 caravan
evening all today when i started my caravan the temp gauge went right to hot and thats where it stood all the way home which is about 3 miles the car did not smoke or over heated. I check the raditor and it was full and the cap was not hot. after dinner whic was about 1 hr i started the caravan it was fine for about 2 minutes then it went to hot again but no smoke or over heating can anone give me some advice what might be causing this problem.
Thanks Michael
Old 06-07-2006, 11:41 PM
KManiac's Avatar
KManiac KManiac is offline
Re: 1994 caravan
If you drove your van over 3 miles with the temperature gauge pegged on H and afterward the radiator was cool to the touch, it can only mean one thing:
Your thermostat is stuck SHUT and water is not circulating out of the engine.
While you were driving your van, your engine got very HOT but the radiator stayed nice and cool. Not a good situation. Hopefully you didn't do an permanent damage to the engine. Do not drive it again until after you change the thermostat.
Now, you did not specify what engine and how many miles. If your van continues to heat like this after you replace your thermostat, you my have a head gasket starting to leak, allowing exhaust gases into the cooling system and creating an air bubble behind the thermostat when cold. This will delay or even prevent the thermostat from opening when it should. This gasket situation is more common in the four cylinder engine with over 100,000 miles. This is what happened to the 2.5L four cylinder in my Shadow.
Let us know what you do and what you discover.
"This car may be old, but it will still climb Kirker Pass at 110!"
1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible
