Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-07-2006, 08:33 PM
Killa's Avatar
Killa Killa is offline
another high idle !!!
I just talk to the owner, he told me the car need new sensor, I was asking him what sensor, he say, you know: when I try to warm up it idle fine, but after it complete warm up it idle around 2k-3k " I was like WTF going on here, I need you guy to help me. please
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 06-07-2006, 09:44 PM
steviek's Avatar
steviek steviek is offline
Re: another high idle !!!
I don't think its a sensor. I think its a vacuum line theres two vacuum hoses that run under your washer fluid normally one is connected to the turbo the other one should be capped that worked for me.
Do you have your check engine light on? and is the error code 505 cause that was my problem.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 06-07-2006, 10:09 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
He dosn't have the car yet...
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 06-07-2006, 10:29 PM
Killa's Avatar
he just send to me the video ( I want to heard the engine, cause he say it lift tick, i thought it was rod knock ), if any one can host this video here, aim me I send it to you 9mb. I dont think he have check engine light.
GM FOR LIFE !!
95 camaro lt1
Old 06-07-2006, 11:09 PM
steviek's Avatar
be careful you can clear the check engine light real easy its probably supposed to be on.
sorry didn't realize its not yours but if it is an idle problem at least its not too serious.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 06-07-2006, 11:13 PM
Killa's Avatar
the car is fine , run and drive great just that high idle problem, you think its ok to run around like that ?
GM FOR LIFE !!
95 camaro lt1
Old 06-08-2006, 01:24 PM
steviek's Avatar
Yea, I did for a while on my car it didn't idle as high as yours but my light was on.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 06-08-2006, 06:56 PM
You can clear the codes, but there is no way that I know of to block the codes from coming back. If the CEL is supposed to be on, it will be....the only reason I can think of getting out of it would be to open it up and remove the bulb.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 06-08-2006, 08:44 PM
steviek's Avatar
When I would reset mine it wouldn't come on for another of couple days (normally after a long trip).
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 06-08-2006, 09:01 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
That's because your problem didn't trigger a code until a couple of days later. It doesn't stay off or any certain amount of time after resetting the system. I've had codes come back immediately after resetting the system.
Killa, you should be fine to drive it like that. Just when you get it, go to Vatozone and get the codes checked to see if there are any in memory that aren't showing up at the moment, that might help you to diagnose the problem a bit.
95 Talon TSI AWD
97 Eclipse GST
