Old 06-07-2006, 08:33 PM
scott6497 scott6497 is offline
Transmission Problem? 2000GT
Wondered if anyone was familiar with syptoms of Torvington or differential bearing failure? Car makes grinding sound similar to bad hub bearing, but replaced those with OE. My mechanic has suggested possible tranny problem.
Old 06-07-2006, 09:22 PM
troy1 troy1 is offline
AF -Advisor
Re: Transmission Problem? 2000GT
Have you gotten it stuck or did any one wheel burn outs? You don't seen the Torrington bearings in the diff go much but inside the trans the Input planetary bearing goes a lot. Also the input drum bearings are troublesome also. I would defiantly advise a tranny pan drop and see what in the pan or contaminates.
Troy
Also how many miles on your car and did he check for a bad tire.
