Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 06-07-2006, 07:45 PM
excheezhead excheezhead is offline
Re: 2001 Jimmy - Code 0440
Originally Posted by old_master
P0440 is "EVAP emission control system malfunction". I would suspect the slow fill has something to do with it. Check the filler tube and vent hose for kinks or obstructions first. If they're ok, to correctly diagnose it, you'll need to follow a diagnostic flow chart.
old master, were you the one that posted the gm service bulliten about csfi injector cleaning and conversion to mfi? i can't find the original post and there are some members that seem like they need it.
thanks
Old 06-07-2006, 07:52 PM
old_master's Avatar
Advisor/Moderator
Hmm, sorry not me. I can't figure out why anyone would want to change from sequential to multiport. It's like a quantum leap...backwards.
Old 06-07-2006, 07:55 PM
blazee's Avatar
blazee blazee is offline
Problem?
The MFI conversion that he's talking about is like the CSFI. It's still sequential, and is a direct replacement. The only difference is that the troublesome poppet valves are replaced with 6 mini injectors.
Old 06-07-2006, 08:03 PM
old_master's Avatar
Advisor/Moderator
Now that I think about it, I do remember reading that. It don't think it makes the system sequential, that would require PCM programming and bla bla bla, it just eliminates the poppets. Maybe a forum search for "poppets", I know it would bring up a boatload, but it would be there!
Old 06-07-2006, 08:06 PM
blazee's Avatar
Problem?
Now that I think about it, I do remember reading that. It doesn't make the system sequential, it just eliminates the poppets. Maybe a forum search for "poppets", I know it would bring up a boatload, but it would be there!
It's in this thread:
http://www.automotiveforums.com/vbul...d.php?t=542117
Old 06-07-2006, 08:15 PM
thats the one i'm talkin about, thanks, blazee, the brain locker for us who hve killed too many!!! them bulletin is very step by step, and the part numbers were available from the dealership for a fair price, comparable to aftermarket injectors, and takes the poppets out of the equazion for good.
thanks guys.
Old 06-07-2006, 08:18 PM
old master, i'm havig a hassle finding matching color paint, and your truck avatar looks the same as mine. i called around and gave all the rpo code and the color qouted is not what my original window sticker says. what color is your truck??
thanks.
Old 06-07-2006, 08:24 PM
blazee's Avatar
Problem?
We're messing up this thread. I'm going to split the off topic posts to a new thread titled "Questions"
Old 06-07-2006, 08:27 PM
blazee's Avatar
Problem?
Re: Questions
If you post your RPO codes. I'll look up the colors. They might have made a mistake.
Old 06-08-2006, 05:51 AM
Re: Questions
thanks again, be back soon.
OK, here is the code from the glove box sticker. this is the first gm truck i've owned that didn't have them on the door jam.
BC/CC U 379E 92H
original factory gmc built in janesville, wi. window sticker says "paint code-magnetic red metalec clear coat" i've seen alot of jimmy's this color, but the chevy equivelant is just a hint red'er.
thanks for your help. the closest i have come is "color match touch up paint" but it says some kind of purple metalic pearl.
i know the "bc/cc" is base coat/clearcoat, but the rest is still a mystery.
Old 06-08-2006, 01:16 PM
blazee's Avatar
Problem?
Re: Questions
Sorry it took so long to reply. I read your post the first time, but didn't realize that you had came back and edited it.
On the sticker you'll see a two digit number followed by a U. I need that number. If it's two tone, I'll need the two digit number followed by a T or L, too.
Old 06-08-2006, 02:51 PM
Exclamation Re: Questions
not to be too stupid, but where else is the number, cause there are like 4-6 rows of 8-10 rpo's and the number i sent was the full at the bottom line other than the rpo's.
p.s. i have to sign off, a raging thunderstorm just started, gotta love florida!!
Old 06-08-2006, 03:03 PM
blazee's Avatar
Problem?
Re: Questions
It's in the list of RPOs. The two digit number is a color code, and the following letter tells the part of the blazer. EX. U is the primary exterior color. I is the interior color. T is the trim color. etc.
It just started raining here too.
Old 06-08-2006, 03:42 PM
Re: Questions
i went to gm's web page and for my 2001 gmc jimmy(s15) the code is 379E, they say it is the number after the U. If this is wrong, let me know.
thanks for all your help.
Old 06-08-2006, 03:56 PM
blazee's Avatar
Problem?
Re: Questions
It's in both locations. The list I have is for the codes inside the RPO list.
