Old 06-07-2006, 06:14 PM
jcase350 jcase350 is offline
Fuel Pump relay
I have a 1990 camaro Iroc-z TPI with a 350. I am having problems getting it started and think it's either the fuel pump or the fuel pump relay. Problem is i don't know which relay is for the fuel pump. Does anyone know or know how to find the info I need. Thanks
1990 Iroc-z 350 TPI
Old 06-07-2006, 09:26 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
Re: Fuel Pump relay
On my 87, the fuel pump relay is in the upper righthand corner, there's 3 relays and it's the middle one. The dead giveaway is that the fuel pump relay has a rubber part so that you can flex the relay back and forth to remove it.
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Old 06-07-2006, 09:41 PM
AFI 05 AFI 05 is offline
Send a message via AIM to AFI 05
Re: Fuel Pump relay
when you turn the ignition.. do you hear the fuel pump priming..? it should do it for like 2-3 seconds... if you DO hear it.. then neither the pump nor the relay are bad.. but if you dont hear a thing, it could be either or.
1990 IROC-Z 5.7 TPI (1 out of 4,213 IROC's made in 1990) Only mod is magnaflow 3" cat back and K&N filters... im broke.
Old 06-07-2006, 09:46 PM
Dyno247365's Avatar
Re: Fuel Pump relay
The FP relay could be failing and it's better to replace it with a new one.
Old 06-07-2006, 09:47 PM
Re: Fuel Pump relay
for my car.. oh shit we have the same car.. well anyway.. the fuel pump relay is the relay to the far left of the 3 if your looking at the engine bay from the front of the car.
Old 06-07-2006, 09:54 PM
Dyno247365's Avatar
Re: Fuel Pump relay
On mine, the far left is the MAF sensor relay. There's a chance it's different.
Old 06-07-2006, 09:55 PM
Re: Fuel Pump relay
we dont have a MAF.. his is a 90'
Old 06-08-2006, 08:57 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Fuel Pump relay
Gentlemen, let's not over look that pesky 'hidden' fuse by the battery for the f/p & ecm.
Old 06-08-2006, 07:53 PM
Re: Fuel Pump relay
What and where is this fuse by the battery?
1990 Iroc-z 350 TPI
Old 06-08-2006, 08:38 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Fuel Pump relay
it's a fuse for the fuel pump relay, and it's located by the battery.
Old 06-09-2006, 12:23 AM
Re: Fuel Pump relay
ahh thats right.. its in one of those black weatherpack fuse holding deals around the battery by the inner fender.
Old 06-09-2006, 08:48 AM
Re: Fuel Pump relay
So the Fuel Pump relay is not one of three located on the firewall?
1990 Iroc-z 350 TPI
Old 06-09-2006, 09:12 AM
wrightz28's Avatar
Re: Fuel Pump relay
Yes, the one in middle on most years.
By the battery is a 20A fuse for the circuit. It's on the fender right over the battery, look like a dead end connector but when you open it, voala, there's a fuse in there.
Old 06-09-2006, 02:12 PM
Re: Fuel Pump relay
I found the fuse by the battery and it is still good, so I'm leaning towards the fuel pump being bad. Also, I tested to see if there was any fuel coming out of the bleed valve on the fuel rod, there wasn't any. Fuel Pump??
1990 Iroc-z 350 TPI
Old 06-09-2006, 02:22 PM
wrightz28's Avatar
Re: Fuel Pump relay
How did the relay check out?
You know what, I jsut thought about it, you shouldn't have 3 relays on the firewall 'cause you'r car dosen't use a MAF.
