Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 06-07-2006, 06:11 PM
casey38boost casey38boost is offline
Headlights don't work need help
Hi,
I have a 93 tunderbird that I just aquired, and the headlights don't work. I went to autozone, replaced the headlight switch, and they are still out. The marker lights work, and the high beams work.
Also the headlight fuse in the engine bay is ok too.
What else should i check?
thanks.
Casey
Old 06-08-2006, 01:25 AM
KimMG KimMG is offline
AF - Advisor
Re: Headlights don't work need help
Did you check the headlights themselves? It is possible that both of them are burnt out.
Did you check to see if you are getting power to the plugs that connect to the headlights? If no, then check the connections to the multifunction switch on the steering column.
Did you replace the headlight switch because you guessed or did you test the switch? Do you have a wiring diagram? If not, www.autozone.com may have one for your car in their free repair guide section. Use a test light or meter and test the appropriate components.
Old 06-11-2006, 10:29 PM
SAM89 SAM89 is offline
I had the same problem on my 89, there were 2 different headlight switches mine had 7 connectors the one autozone sold me had 9 , i went to carquest they had the 7 conector one, it works now, with the 9 connector no headlights
Old 06-25-2006, 10:49 AM
8ate8 8ate8 is offline
Send a message via ICQ to 8ate8 Send a message via AIM to 8ate8
It's most likely the multi-function switch (blinkers, wipers, hazards switch). They are prone to going bad. On my 96 my blinkers would only work 50% of the time, and on my 93 I had the same problem as you. High beams worked and so did the turn signals, but no headlights.
1996 Thunderbird LX 3.8L
1993 Thunderbird SC 3.8L
2000 Cherokee Sport 4.0L
2005 Tacoma X-Runner
Jersey Rice
NJ Thunderbird & Cougar Club
Old 06-25-2006, 08:44 PM
Mike75 Mike75 is offline
Check out this link to see if your Bird is covered by the recall:
http://www.alldata.com/TSB/19/93190711.html
I had what sounds like the same problem (as did many others here), but my local dealership took care of the problem for me - for free. Good luck, either way.
