Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-07-2006, 04:38 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Throttle body coolant bypass to turbo?
I'm going to be installing a Mitsubishi turbo on my car, and as far as i know it has to be watercooled. So I was thinking about running the turbo coolant lines from the throttle body coolant return to the turbo. I was telling my LS1 buddy about it, and he said that I should just bypass the throttle body completely, and just cap off the coolant fittings on the throttle body. He's got it done on his car and he says it will probably make mine run better and give possibly more power. So my question is is this a good idea or should I continue to run coolant to the throttle body and run the turbo off of the throttle body return? Will bypassing the TB hurt performance or drivability? And the million dollar question.....will it hurt the gas mileage?
Thanks for any help in advance.
vanilla gorilla
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 06-07-2006, 05:05 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Throttle body coolant bypass to turbo?
Do you live in a cold (freezing) area?
now - 2000 civic
soon - 2002 is300
Old 06-07-2006, 08:38 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
I read a write up about this. Basically, if you live in an area where it is normally hot or warm all the time like Florida or something smiliar then this mod should not hurt you at all. If you live somewhere were you get pretty hard winters and it gets pretty cold outside then I probably wouldn't do it. Having the coolant run through the TB helps so the TB does not freeze when it is very cold out. I have heard of a minimal power gain if any from it because the TB would not be warm from the coolant running through it but, the gain is not really noticeable.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 06-08-2006, 04:38 AM
kjewer1 kjewer1 is offline
AF - Advisor
There are a lot of misconceptions out there regarding what the coolant lines to the TB do (not necessarily in this thread), at least on DSMs. I'd like to take a moment to try to clear some of them up. I would expect all Mitsu cars to work like this as well. I've run without the FIAV and the ISC, using the closed throttle switch to adjust idle speed, carbuerator stylee, so I have some personal experience in this area.
The coolant passes through the Fast Idle Air Valve (FIAV). The FIAV is a waxed based valve (not unlike your thermostat) that reacts to temperature changes, bypassing air around the throttle plate in varying amounts. It is a "Normally Open" valve, meaning at atmospheric temperatures it is open, at least partially. On a cold winter's day, it's wide open. On a hot summer day, it may only be slightly open.
Having that valve open rasises idle speed, since it is bypassing air around the throttle plate, just like the BISS, and just like the ISC. Once coolant temp comes up, meaning the car is warmed up, the wax FIAV closes, and idle drops to what it is supposed to be as determined by the ISC, since that is now the only thing bypassing air around the throttle plate.
You can probably already see the problem with simply removing the coolant lines from the TB. You'll always have the high warmup idle. This is a real pain in the ass for obvious reasons, like trying to negotiate tight parking lots and such at 2000 rpm, and other reasons, like idle surge from Coasting Fuel Cut, etc. In order to complete this mod, you need to also block off those air passages related to the FIAV. I've done this mod before, and it's not rocket science, but you have to put down the computer and go do some disassembly and investigation to see exactly what it is you need to do. In my case I removed the FIAV and ISC subassembly, and made a block off plate to disable both of them.
Once the FIAV is blocked off, you now lose your higher cold idle/warmup idle speed, since no air can bypass the throttle plate. For poeple in warm climates, this probably won't be a problem. In cold weather it can be a pain in the ass. I found that in reasonable weather (cold but still above freezing IIRC) the choke function in the ECU adding more fuel brought idle speed up just enough to let it run on its own until it was warmed up.
I highly doubt this is worth any real power gains however. I don't think the TB being at coolant temperature is going to put enough heat into the incoming charge air to make a difference. The throttle body is not meant to be a good heat exchanger There is very little surface area invloved, and the air is moving pretty quickly through it. These qualities are the exact opposite of what you try to design into a heat exchanger like a radiator or intercooler. Not to mention that on a turbo car the charge air is not exactly cool either.
Now, using these lines to feed a turbo is an interesting idea and I definitely give you guys credit for it. There is a supply and a return, and they are even the right size. They also appear to be in the same location as the turbo feed lines, at least on the turbo cars, meaning one comes from the head side of the tstat, and the other comes from the front water pipe. So that gives me some confidence that they will still get the job done (cooling the turbo).
Are the driveability trade-offs and extra labor involved in blocking the FIAV off the right way worth it? I don't know, I'm not sure what your other options are in turboing an NT. But hopefully I've provided enough information here for you to make that call based on your local climate.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-08-2006, 07:03 AM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
You have got to be the most amazing person on this damn forum by far Kevin!!!!
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 06-08-2006, 01:50 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
how did you change your name?
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 06-08-2006, 02:32 PM
that's his sn on the dsmlink forums. I would think he would have no problem getting anything administrative taken care of real quick on this forum
now - 2000 civic
soon - 2002 is300
Old 06-08-2006, 04:44 PM
AF - Advisor
Yes, this is the last forum that still had my 6 year old screen name. All others have long ago been updated. I wanted to make this one match, but have been reluctant to bother the admins with it. Admining a site takes a ton of time, and they don't get paid for it, which I know first hand Thankfully they graciously took care of it for me today when I finally asked.
Kevin Jewer
Old 06-08-2006, 08:20 PM
NateS's Avatar
Wow kevin, you made my explaination look like a little kit pissing on an ant compared to you steamrolling the sob. Hahaha.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 06-09-2006, 02:14 AM
MexRocket's Avatar
MexRocket MexRocket is offline
yah, If you were a girl, thor would try to make out with you, maybe that is why my car idles so high =O
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 06-09-2006, 07:28 AM
AF - Advisor
LMAO, you guys are killin me.
Kevin Jewer
Old 06-10-2006, 11:44 PM
Thanks for the info. You guys always help me out. Based on everything you guys have told me I think I will leave the TB like it is...but still feed the turbo from it somehow. I'll tell my LS1 buddy about what I learned.
Caleb
vanilla gorilla
