Old 06-07-2006, 10:42 AM
pokey69 pokey69 is offline
88 Crx acting funny
Hey all,
First off, i was cruising around like i usually do yesterday and ran low on gas, so i went and fueled up, i then preceeded to mickey deee's because i was in need of some grease. got out from mcdonalds and tried firing up my car. starter kicks in, but nothing else. almost like a dry crank, i let it sit and cool right down, still nothing, after a bit of persuasion (i had to hold in a bit of pedal) it fianlly fired but ran really rough, gave it a quick rev and it ran perfect after the system cleared out, it seemed as if it was running righ because it was spitting a bit of black smoke when it was running rough.
I'm getting an engine light, but thats been ever since i've got the car and its the idle controll i do believe because the idle hunts, could this be anything to do with my IACV ( sorry if i got the letters mixed up) thats causing my engine light?
I am driving the dual point 1.5 injected engine btw.
Any help would be greatly appreciated.
keenan
Old 06-07-2006, 11:57 AM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
Re: 88 Crx acting funny
i had that same problem happen to me in the si..always did it when i was gettin gas so id look like an idiot in front of everyone lol but it always cleared right up..dont kno whats makin it happen could be the idle cuz im thinkin thats what messed up my old motor
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
Old 06-07-2006, 12:23 PM
its weird, its only been doing this since its been hot around here (summer time obviously) And it never fucks up right after i get gas, only a few minutes after i cruise. or w/e
its so fucked up.. its annoying me so much. im going to check with my mechanic today.
Old 06-07-2006, 12:28 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
So you've checked the codes blinking on the ecu? What you should do is clean your EACV, then spray water on your hoses. If the surging stops and bubbles can be seen from certain areas, tape the hoses with duct tape. This should help until you replace the hoses. Remember to reset the ecu by pulling the 10a hazard fuse and the 15a ecu fuse.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 06-07-2006, 12:31 PM
i actually havent checked the codes under the carpet, i have no idea where the led is or where to find it. some assistance to finding the blinking light?
Also, the eacv where is it located on the engine? i'm thinking its somewere near the throttlebody
thanks for the help chaps
Old 06-07-2006, 12:34 PM
Then how did you know it was the eacv? Idle surging could be from a number of things.
Go to passenger side, under the glove box there is a button in the corner that holds the carpet in place, unbutton it, count the blinks. Refer to the FAQ thread stickied at the top of this forum for codes.
2010 Honda CR-V EX
Old 06-07-2006, 12:37 PM
Actually, i dont know 100%, thats what im figuring by reading on these forums, Thanks for the input man. and sorry for seeming like a jackass.
Old 06-07-2006, 12:48 PM
4twenty's Avatar
4twenty 4twenty is offline
welcome to the world of ECU codes...
Old 06-07-2006, 02:44 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Yeah, the ECU is under the carpet in the passenger footwell, the center has an led behind a clear window, count the blinks and check back with us..but first pull the hazard fuse in the underhood fuse box on the passenger shock tower..
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 06-07-2006, 02:59 PM
I believe I already stated all of this.
2010 Honda CR-V EX
Old 06-07-2006, 03:05 PM
FrodoGT's Avatar
And he still didnt seem to get it...
Current project:
Rio Red 91 hatch.
Old 06-09-2006, 02:54 PM
its reading a code six. checked the thermostat temps around 180 so i thinking its that.
Old 06-09-2006, 09:51 PM
FrodoGT's Avatar
180 is good, here try this baby out, will tell you everything you need to get that light gone..
http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D
Current project:
Rio Red 91 hatch.
Old 06-09-2006, 10:47 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
coolant temp sensor. It's the two wire sensor on the side of the head under the distributor. Check for continuity between the sensor and the ecu. It will tell you if the sensor circuit is complete and not broken somewhere. This will mess up your idle, because it is one of the sensors that controls your idle, as well as air/fuel ratio. It's actually a VERY important sensor.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
