Old 06-07-2006, 10:06 AM
Dallas Dallas is offline
Unhappy 91 CRX Engine light
I am having a problem with resetting my engine light, The dist. went bad and kicked the light on but will not go off now the dist. has been replaced. Can someone please help me it is driving me crazy?
Old 06-07-2006, 10:49 AM
crx2034 crx2034 is offline
Re: 91 CRX Engine light
disconnect the battery for a minutes or two then reconnect.
Old 06-07-2006, 12:31 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Just pull the 10a hazard fuse and the 15a ecu fuse in the under hood fuse box. No battery disconnecting, no radio/clock resetting...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 06-07-2006, 02:41 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Actually just the hazard fuse will be sufficient, taken straight from the service manual.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 06-07-2006, 03:00 PM
Actually, no it isn't. You sometimes must pull the ECU fuse or it will not reset EVERY code.
2010 Honda CR-V EX
Old 06-07-2006, 03:06 PM
FrodoGT's Avatar
Argue with the Honda service manual, not me dude...
Current project:
Rio Red 91 hatch.
Old 06-07-2006, 03:17 PM
Well, I pulled the hazard fuse when I had code 17 (speedometer cable)... popped out... and it didnt' do a damn thing. Then I pulled the ECU fuse and it reset the computer and cleared the code. Now I pull both every time. Like yesterday when the damn speedo cable popped out again. Or when my dizzy replacement crapped out the crank angle sensor after 2 days (code 4)...
2010 Honda CR-V EX
Old 06-07-2006, 03:52 PM
FrodoGT's Avatar
I had a speedo code as well, cluster was unhooked, Ive never pulled the ECU fuse, and its long gone..several times over now.
Current project:
Rio Red 91 hatch.
Old 06-07-2006, 08:06 PM
Smile Re: 91 CRX Engine light
Hello me again, pulling the fuses did not fix my problem. I was able to get a code off the ECU and it is 8, do you know that means.
Old 06-07-2006, 10:17 PM
FrodoGT's Avatar
Pulling the fuse wasnt meant to fix anything, rather to just clear out any random codes and show you the pertinent ones..#8 is the top dead center sensor.
Here is a troubleshooting flowchart to help you out, my wires were disconnected, it also would make it buck going down the road with steady throttle..
http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D
Current project:
Rio Red 91 hatch.
Old 06-10-2006, 12:43 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
the ecu will sample the code (check to see if the problem still exists) like every 50 or 60 miles. If it looks for the problem again (code), and the problem has been fixed, it will erase the code on it's own. So, even if you don't reset the code, the ecu will eventually get rid of it when the problem is fixed.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
