Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 06-07-2006, 06:57 AM
udfxrookie udfxrookie is offline
Unhappy Engine misfire on one cyl
I have an OBD code for an engine misfire on cycl 4.... I"ve swapped in this order, distr. cap, rotor, and plug.... then the wirse and plug again, and it still misfires.
What could be wrong.
P.s.
I do have a faulty O2 sensor that needs replaced also but I didn't think this would cause a misfire.... it's in bank three I believe.
Old 06-08-2006, 02:14 PM
99avenger2.5 99avenger2.5 is offline
Re: Engine misfire on one cyl
what year is the truck? The 92-95 4.3L engines have problems with their spider injectors.
Old 06-08-2006, 06:24 PM
2000
Old 06-17-2006, 04:23 PM
platinumjason platinumjason is offline
Send a message via AIM to platinumjason Send a message via MSN to platinumjason Send a message via Yahoo to platinumjason
Sounds like the same problem mine is having. No clue why.
Old 06-18-2006, 12:01 AM
old_master's Avatar
Advisor/Moderator
Possibly a vacuum leak in the #4 runner of the intake manifold. Cylinder #4 is the center cylinder on the passenger side of the engine. Try directing a fine spray of carb cleaner along the intake and notice if the RPM increases and/or idle quality improves. Another trick is to put one end of a 3/4" heater hose next to your ear and move the other end around searching for the leak. When you get near the leak, you'll hear the hissing sound loud and clear through the hose. Hope this helps.
