intake spacer?
i need a intake spacer so i can put my tall valve covers on. i have a stock intake and a 2 1/2 cowl hood. i would like to use the 1 inch spacer to give myself plenty of room but would it hurt the performance of the car? should i get a 3/8 or 1/2 inch instead?
87 5.0 5 spd T-Tops - mass air conversion 9AL, msd distributer, coil, fms 9mm wires, bbk ceramic coated long tubes, bbk h pipe, 3" flowmaster catback, 190 lph fuel pump, 24 psi injectors, 70mm cobra meter, bbk AFPR, bbk fender kit with k&n filter, 12* base timing, flex fan, 3 row aluminum radiator, 6 piece headlight kit w/ clear corners, silver ponys, stormin normin cowl hood, saleen wing, and recently a new heater core
Re: intake spacer?
I'm not sure on the stock intake or EFI intakes all together. But I know with carb intakes a spacer will normally add some HP on the top end due to better fuel atomazation. That wouldnt happen with an EFI intake though. But to answere your question no I dont think it will hurt performance.
1969 Cougar 357w & TKO - 475hp |
