Old 06-06-2006, 06:57 PM
GhettoSmurf GhettoSmurf is offline
Car Problems
Was going down the road to work and my car quit on me. I drive a '96 camaro with the 3.8 engine. If i let it sit long enough it'll crank up but it won't stay running for more than a few seconds. Alot of people have told me that they think that its the fuel pump but I'm not sure. I checked the electrical circuit to it and it checks out good so i tried sittin underneath the car while someone turned the ignition forward because many people said that you could hear the fuel pump come on but i heard nothing. Someone else told me to take the hose coming to the fuel filter from the fuel pump off and it should spray a stream of gas out when the ignition was turned forward but it didn't even drip. Any other suggestions as to what it may be, cause a fuel pump for this car ain't cheap. Any suggestions are appreciated. Thnx.
'96 Camaro 3.8L V6
-Cold Air Intake
-Flowmaster Exhaust w/ chrome tips
-XenoLights (blue)(dims & brights)
- Premium Sound Package w/SonyXplode CD Player,
bridged 250rmsw Apex Amp, 12" Kicker Comp Sub
-Air Freshener
Old 06-06-2006, 07:07 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
Re: Car Problems
sounds like a fuel pump to me. The easiest way to check it is by hooking up a fuel pressure gauge.
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 06-06-2006, 07:24 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Re: Car Problems
dont even think you need to do that, if it doesnt spray then its not pumping enough or not at all.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 06-06-2006, 07:32 PM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
Re: Car Problems
Sounds like the fuel pump to me.
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
Old 06-06-2006, 10:32 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Re: Car Problems
make sure you checked the feed line, not the fuel return line. the feed line is the larger of the two. and also i hope you were at the back of the car when you were layin under it, by the tank... because of course, thats where the pump is.
if after all this, you still get no results. check the pump fuse. on third gens the fuse in near the fender, i believe yours would be under the dash. my fuse have blown on several occassions for some odd reason. if this doesnt fix it, then check for shorts, or damage in the wiring... otherwise replace fuel pump.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 06-07-2006, 08:58 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Car Problems
Get a gauge and verify the pressure although it's a fair bet the pump took a dump.
Old 06-07-2006, 05:32 PM
Re: Car Problems
Yes i was at the back of the car heh. And i've check all shorts and wires on it and they're all good, so i went and spent $283 dollars on a brand new fuel pump due to the miraculous wonder that not a single junk yard had one for my car.
Another question then. I've just replaced my coolant sensor, and my thermostat, and as far as i know none of my hoses on my radiator are leaking, but here lately when i drive it, it loses almost half of whats in the radiator everytime. I've never let it overheat to much but it still gets to hot for me to be comfortable driving it. But still I can't figure out where its going cause its not steaming up on the motor either. And the radiator has been flushed twice since i've had the car, and thats maybe been 8 months??
'96 Camaro 3.8L V6
-Cold Air Intake
-Air Freshener
Old 06-07-2006, 06:04 PM
Re: Car Problems
are you kidding me? My aftermarket walbro high performance pump cost like $100 ....or did you have to buy the whole fuel pump module?
Old 06-07-2006, 06:09 PM
Re: Car Problems
whole module... but if i can get a better and cheaper one i'll take it back and ride the kawasaki for a few more days...
'96 Camaro 3.8L V6
-Cold Air Intake
-Air Freshener
Old 06-07-2006, 07:39 PM
jcase350 jcase350 is offline
Re: Car Problems
The coolant could be leaking out of the water pump.
1990 Iroc-z 350 TPI
Old 06-08-2006, 03:58 AM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
Re: Car Problems
do you see steam coming out of the exhaust pipes? i hope you dont have it, but you might have a blown head gasket/ cracked block?
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 06-08-2006, 09:12 AM
wrightz28's Avatar
Re: Car Problems
Before we go scaring the man into thinking his car is trash, what about the infamous 4th gen overflow tank leak?
Also, replace the radiator cap, should have with the niew stat.
But ghetto, a USED fuel pump form a junkyard? That's pretty ghetto
Old 06-08-2006, 02:29 PM
Re: Car Problems
if car gets too hot the pressure of the coolant will also exceed the radiator cap limit. thus when car gets too hot the cap allows the coolant to flow out of radiator into the resovoir (how is that spelled?). the coolant may have overflowed out of the resovoir. some of the resovoir caps (not radiator caps) intentionally aren't sealed because of this.
you may have the incorrect radiator cap for your car. which would cause overheating and possibly coolant loss.
this is probably it.... since you say it runs too hot and you didn't mention white smoke from the exhaust. the only other possibility is coolant entering the oil thru the heads. check oil... if it's an obvious lighter brown color or if there's white stuff on the oil cap, then you have a bigger problem.
Old 06-08-2006, 07:48 PM
Re: Car Problems
Oil is a dark color, and not watery looking but i'll try it again once i get it running. The cap on the coolant resevoir is extremely loose, it screws on but it is easily pulled off. And smoke does come out the exhaust when it first starts but not after that.
Now on to my previous question...Is there any way in hell to get this gas tank out without cutting my exhaust off. I've got everything undone and its ready to drop but i can't angle it out on the right side of the car far enough to completely drop it.
And i got one too =) for $25 dollars
'96 Camaro 3.8L V6
-Cold Air Intake
-Air Freshener
Old 06-08-2006, 09:02 PM
Re: Car Problems
exhaust has to come out and have fun dropping the tank... it actually has to be angled front to back and then angled toward the front of the car to come out... it's one fun job.... you do have your rear dropped too right?
