Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 06-06-2006, 05:26 PM
sreilly77's Avatar
sreilly77 sreilly77 is offline
EGR Valve
I have replaced the EGR Valve, EGR Tube, DPFE Sensor, and EGR Solinoid just recently due to my CEL coming on. I ran the code and it said "EGR Flow Insufficient." I cleaned the carbon out of the system thoroughly and I still get the code after about two cycles of driving. Did I forget to replace something else? The car is running so much better yet I am still getting the CEL. I should also mention that there is no vacuum leak and the valve opens when it is supposed to. I'm baffled. I don't get any misfire, knocking, pinging, or anything. The car runs really good!
Sean
Old 06-06-2006, 05:34 PM
carlos80 carlos80 is offline
Re: EGR Valve
use a vac pump and open the valve while, at idle, the car should stumble if it does that means enough flow and your problem is electrical, perhaps maybe the hoses running to the DPFE.
Old 06-06-2006, 06:55 PM
sreilly77's Avatar
Re: EGR Valve
ill give it a try. i am going to give it a tune up on saturday. i'll let you know how i make out. thanks.
Sean
Old 06-07-2006, 12:44 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
Re: EGR Valve
u clean the horseshoe passages under the upper plenum also did u disconnect the battery?
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 06-07-2006, 03:52 PM
sreilly77's Avatar
Re: EGR Valve
yes i did. im startin to believe that there is an electrical problem. i have a spare computer for the car im gonna swap computers and see what happens. i know that before i did the EGR system, i cleaned out the entire system of carbon, replaced all parts of the EGR system, then cleaned out the system again. after all this i replaced the O2 sensors, however it dawned on me today that i never changed the spark plugs and wires after i did all this. i pulled a spark plug out today and it was really covered up with carbon deposits. i have a feeling that is problem why i am still getting the CEL and code for the EGR flow. i'm going to do the spark plugs and wires saturday. first, i will clean the system out once again of any carbon bulid up (i really don't think there is any), then i am going to replace the spark plugs and wires. lets see what happens then.
Sean
Old 06-07-2006, 04:18 PM
Re: EGR Valve
i would first try disconnecting the batter both termanals and take a wrench and touch the two cables together for about a min this will ground out and power in the system thus resting everything back to ford specs then let it sit for bout 15 min with the battery un hooked then hook it back up and u should lose all your pre sets and your clock should be at 12:00 then when u start it it will run like s**t just take it for a drive and drive normal then look for the cel again
Old 06-07-2006, 08:56 PM
sreilly77's Avatar
Re: EGR Valve
i will do that tomorrow and let you know what happens. thanks.
Sean
Old 06-08-2006, 04:53 PM
sreilly77's Avatar
Re: EGR Valve
well, i tried what you said. so far so good. ill let you know how i make out in a couple of days. the town car sits during the week because i drive my work truck back and forth to work. so i will let you know saturday what happens after i do a tune up. thanks again.
Sean
Old 06-10-2006, 03:39 PM
Mr Wiggl3s Mr Wiggl3s is offline
Banned
Send a message via AIM to Mr Wiggl3s
Re: EGR Valve
Well, its pretty damn obvious that these year town car's sensors are horrible. Maybe nothing it wrong with it at all.
Old 06-12-2006, 09:31 AM
Towncar's Avatar
Towncar Towncar is offline
Re: EGR Valve
I was having an un-explained EGR problem, with P0171 and P0174 codes as well. Cleaned out everything EGR related (there was no soot in there) and still had the codes.
Took someone's advice and had a look at the MAF Sensor, sure enough, there was a hair and plenty of crud on the wires. Cleaned the wires, re-set the OBDii system, and viola.. no more problems with the CEL.
-Steven
1996 Town Car, Cartier
Old 06-12-2006, 03:22 PM
sreilly77's Avatar
Re: EGR Valve
yea the CEL did come back on. i am going to give that a try. thanks!
Sean
Old 06-14-2006, 08:42 PM
sreilly77's Avatar
Re: EGR Valve
hey steve, i tried to get the MAF sensor off but i couldn't. what tool did you use? i tried using an allan key but it wouldn't work. like it wouldn't sit in right. how did you get it apart?
Sean
Old 06-14-2006, 08:48 PM
Re: EGR Valve
i can help you here you need a tamper proof torx bit im not pos but i think its a 22 i believe it says it in the article i posted hope this helps
Old 06-15-2006, 01:13 AM
Towncar's Avatar
Re: EGR Valve
Yep, Cobradude hit the nail on the head. I'm not positive of the Torx Bit number either, I have the whole Security (tamper proof) set so I just tried them till I found the right size, didn't pay attention to the number on the Bit.
The Torx head is a six point star pattern, and the security head has a stud in the center preventing the Bit from going into the head of the screw. The Bit has a hole drilled in the end that fits over the stud in the head allowing the tool to enter the screw head.
I got my 33pc set from the local Harbor Freight for $2.99 + local tax
-Steven
Old 06-15-2006, 06:00 PM
sreilly77's Avatar
Re: EGR Valve
thanx! im going out right now to get a set.
Sean
