Old 06-06-2006, 03:48 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
289 to 347 possible?
Hey Guys I came here to get some quick info on my friends 65 mustang build up he currently has a ford 289 in it and I was wondering if we can stroke it to 347 or will we run into problems in doing it? I know you have to notch it but is that it? Tried search on here but couldnt find nothing useful...
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 06-06-2006, 06:09 PM
turboEKhatch turboEKhatch is offline
Re: 289 to 347 possible?
The 289 has shorter bores than the 302's which can pull the piston out of the bottom of the bore at BDC. It'll work, but it will probably wear the skirts much worse than with a 302 block. Unless you want a numbers matching car (which I assume isn't a big deal, considering a 65 coupe with a 289 isn't an exactly rare car) I would go to a junkyard and pickup a 302 block to start from there.
Old 06-06-2006, 06:10 PM
TheStang00's Avatar
TheStang00 TheStang00 is offline
Originally Posted by turboEKhatch
The 289 has shorter stroke than the 302's which can pull the piston out of the bottom of the bore at BDC. It'll work, but it will probably wear the skirts much worse than with a 302 block. Unless you want a numbers matching car (which I assume isn't a big deal, considering a 65 coupe with a 289 isn't an exactly rare car) I would go to a junkyard and pickup a 302 block to start from there.
i think thats what you meant...
Old 06-06-2006, 07:53 PM
351wStang's Avatar
351wStang 351wStang is offline
Shorter stroke yes, but the cylinders are shorter as well. As stated, with the shorter cylinder in the 289 and the increased stroke of a 347 you will be "overextending" if you will, the pistons. This will cause you problems eventually. If you are going to put the money into this motor for a stroker kit then spend about $200 and get a 302 from the junk yard. If you are local to me I will sell you a 1976 302 bare block with mains for $100. This is an older block as is supposed to be stronger than the 5.0 era blocks.
1969 Cougar
357w & TKO - 475hp
Old 06-06-2006, 10:01 PM
I live in california, think it be way to much to ship probably...so I guess I have to get a 302 block...will all my parts switch over if i only find a bare block with no main jornals or anything?
90 Honda CRX Si
-Red/Black
-B20B/b16
Old 06-06-2006, 10:27 PM
also can I use any bottom end 302 and if so up until when?
90 Honda CRX Si
-Red/Black
-B20B/b16
Old 06-07-2006, 03:05 PM
351wStang's Avatar
The average 302 stock bottom end is safe up to about 500hp. I cant remember the deck height on a 289 so I'm not sure if the intake will work. But I think the heads & intake will work. Dont quote me on that because I'm not positive. You would need to use a 302 rotating assembly as well. Now, again I am not 100% positive on this but I think 1965 was the year the 289 changed a little. There are 2 different 289's. The latter of them has the common windsor bellhousing bolt pattern. The earlier 289's had I beleive a more narrow bellhousing bolt pattern. If you have the earlier block then your transmission will not bolt up to a 302. Just something to look out for.
1969 Cougar
357w & TKO - 475hp
