Old 07-30-2002, 05:56 PM
primera man's Avatar
"P-Man"
Question Do you see what i see ......or is it just me ??? (competition time !!)
Just a little competition.
Take a good look at this photo and see if you can notice anything in the last 2 models i built......scroll down for the answer, then you can comment and see if you got the same answer as me
.I reckon Fujumi have there 1/24 scales up the shit.
Now I've yet to see a new typeR in NZ, but have seen plenty of Silvia's and i think the Silvia should be a lot bigger car.
Look at the photo and IMO the TypeR looks alot bigger then the Silvia....what do you think???
Maybe someone from the USA who has seen a TypeR might be able to clear this up.....but i think FUJUMI have stuffed up there scale.
View All My Models Here.
Old 07-30-2002, 06:04 PM
rcmaxx rcmaxx is offline
the skirt on the silvia looks cool from the side but corny from above like that. nice!!!!!!!! NICE LINES!!!!! thank you!!! they make you models 10 times better. drool at the type r. also, silvia does'nt come to the US but the 180sx IS alot bigger then the integra(NSX)
Old 07-30-2002, 06:24 PM
barnabei's Avatar
barnabei barnabei is offline
yeah, looks to me like the silvia might be more in scale with a honda crx. maybe this is their new 1/27 scale i always thought that the silvia was a slightly bigger car myself. must be nice to have two nicely completed models side by side to be able to compare
Old 07-30-2002, 06:29 PM
daggerlee's Avatar
Well... Here are the raw specs:
'99 Nissan Silvia:
Length: 4445 mm
Width: 1695 mm
Height: 1285 mm
Wheelbase: 2525 mm
'02 RSX
Length: 4375 mm
Width: 1725 mm
Height: 1389 mm
Wheelbase: 2570 mm
So...the Silvia is 70 mm longer than the RSX. In scale, the Silvia should be 3 mm longer than the RSX (by dividing the difference by 24). The RSX is wider than the Silvia by 30 mm, or 1.25 mm in scale. The RSX is 104 mm taller than the Silvia, or 4.3 mm taller in scale.
Judging by your pics, I think fujimi did a pretty accurate tooling of both kits. I haven't seen a Silvia up front yet but I have seen several RSX (what we call the new type Rs here in the US) on the streets, and let me tell you they are much beefier than the previous Type R. Just my 2 cents.
Old 07-30-2002, 10:42 PM
Daryl's Avatar
Daryl Daryl is offline
The first thing that came to my head was a panel line comparo
But seriously, I think Fujimi have their scales a little messed up. I ordered a set each of fujimi and aoshima 18in rims and they are not the same size. I also reckon my fukimi MR2 should be a little wider, judging from 1:1 MR2s i've seen. Mine looks a little narrow.
Left is right. Right is wrong.
Old 07-30-2002, 11:28 PM
XenoKryst XenoKryst is offline
Send a message via ICQ to XenoKryst Send a message via AIM to XenoKryst Send a message via Yahoo to XenoKryst
Originally posted by daggerlee
...I have seen several RSX (what we call the new type Rs here in the US) on the streets, and let me tell you they are much beefier than the previous Type R.
I don't believe America have ever received ACTUAL front line Type R's just as the Japs do. Instead, we get GSR, GSX, RS, etc in the previous models of the Integra. Now-a-days, we are fortunate enought to receive Type S, not quite a Type R but its slowly getting there. The only Type R's in America would be the imported ones (excluding engine transplants! ). Just thought I would clarify a little.
The new Integra's (RSX) don't really look so good to my prospective without a few mm of lowering and adition to some swell side skirts and maybe front and rear ones too. Nothing extreme but just to give it a nice flare. I think the Integra is really high as a stock model in real life. The front is lower than the back makes it look weird.
On a lighter note, Fujimi does do some weird things. I really hate the low detail to the headlights, it just takes so much away from the realistic look of the car.
Current Project:
Mitsubishi FTO
Old 07-31-2002, 01:04 AM
ales's Avatar
ales ales is offline
Forza Schumacher
Warren, the best indication is the wheelbase (the easiest to measure). Just measure i on the models and compare to specs
Old 07-31-2002, 04:37 PM
garrettwc garrettwc is offline
To clarify a little more, 3 years ago I worked for an Acura dealer and we did have a full Type R. This was a separate car from the ones listed above and was only available in white. Later they added them in yellow and black IIRC. They skipped a year in between where they didn't make them. They came direct from Honda with all US emissions and other requirements in place. We only got two in the entire time I worked there. Honda made them only in very small numbers. The horsepower difference between the Type R and the GSR was only 25-50. The Honda rep told me the cars start life as a basic RS and are stripped down, rewelded, and blueprinted. Then all the go fast goodies are added.
Old 07-31-2002, 05:20 PM
Mr Mario's Avatar
Mr Mario Mr Mario is offline
Well this what I know...
The GSR has 170hp, the USDM Integra Type R has 195hp basically
the only thing that the type R and the RS motor share is the 1.8L displacment. The Type R is not a stipped down RS that has been rewelded and blueprinted. The Type R has a totally different suspension
and the engine is a VTEC the RS is non VTEC. There is many many differences that seperate the two models.
That's all
:flash:
Old 07-31-2002, 05:36 PM
Jay! Jay! is offline
Horizontally Opposed
Well, I can find ITR blueprints, but no Silvia prints. I can confirm that Dan's dimensions from '99 are the same as '02 for the Silvia...
Hierarchy of Subaru:
(Click to see mine!)
Old 08-01-2002, 07:07 AM
That's all
:flash:
Maybe I should have been more clear. You are correct that all the drivetrain and suspension pieces are totally different and have nothing in common with the RS. What I was referring to was the rolling chassis. Those do come from the standard RS line. They go over every inch of the unibody adding additional welds to help stiffen the car up. When the cars are reassembled they get more "hand fitting" or "blueprinting" than a standard production chassis.
Again this is coming from the man who was our Honda factory rep at the time. It is only my assumption that he was giving correct information.
Old 08-01-2002, 06:33 PM
Mr Mario's Avatar
It's all good :flash:
Old 08-02-2002, 08:33 AM
:ylsuper
Need help to see if what I'm seeing is real or not. white_R34 COMPLETELY off-topic 2 12-30-2007 12:51 PM
just thought you guys should see this ad. Christ Classifieds 5 09-29-2007 09:49 PM
Just got a 98 Accord, just checkin to see what I need to know. chavocrazy69 Accord/TSX/Accord Hybrid 1 12-04-2006 11:16 AM
