Old 06-06-2006, 02:10 AM
SaphusGT's Avatar
SaphusGT SaphusGT is offline
I blew my engine
It would seem... that... my engine is blown.
I am extremely upset...
fucking camaros...
where's the rope?
Old 06-06-2006, 09:25 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: I blew my engine
Blown as in a rod through the block?
Old 06-06-2006, 10:04 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
This is a camaros fault because??
I think we need a little explination on what YOU did and why you think the engine is blown.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 06-06-2006, 11:35 AM
SaphusGT's Avatar
well.... If you're in a race... and you get up to fourty to throw it into second for some extra boost then accidentally overthrow into FIRST then realize it after its redlining in 8... then... yeah... (I think it might just be a rocker arm...) it dies after start up... and knocks.... and dies w/o constant gas given.... it's screwed...
Old 06-06-2006, 01:20 PM
2old 2old is offline
It's more likely a bent valve or a jumped timing belt...
Instantaniously exceeding the redline is more likely going to exceed the speed that the valve spring can return the value to it's it's seat so the piston might have made contact with one or more of the valves.
It's probably more of a PITA to find and fix then a write off...
[edit] Can I ask... How did you mistake 1st for 2nd? 3rd I understand... But second?!?
Old 06-06-2006, 01:59 PM
aerosoul aerosoul is offline
damn that sucks saphus didn't you just get your 3S? but, yeah how do you mistake 1st and 2nd? good luck getting that fixed.
Old 06-06-2006, 02:34 PM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
could've warped the heads too
Georgey on the subject of midget beastiality pornos
Originally Posted by 1viadrft
I've seen a video or two out of curiousity.... those damn midgets are hung! But then the donkey walks in...
Home Puta's 4Life Crew Member #1
R.I.P Andy, you will be missed by all.
Old 06-06-2006, 02:58 PM
There is a lot of things that could have happened, but most likely it didnt cause any real damage unless you drove it home after that with it knocking and not staying running.
Side note: It takes a bit of force to get back into 1st when you are at the top of 2nd, while 3rd just goes right in.
"So I got my car 2 weeks ago and Im racing it, but dont know how to shift yet........where did I go wrong?"
Old 06-07-2006, 12:29 AM
SaphusGT's Avatar
It's an automatic transmission... if that helps
*edit* correction... i got it a month ago
Old 06-07-2006, 12:50 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Well there ya go. You should NEVER try to manually shift a ATX.
Old 06-07-2006, 09:44 AM
TorchedStealth's Avatar
TorchedStealth TorchedStealth is offline
Send a message via MSN to TorchedStealth
You were at 8k going 40-45? I have an auto and mine is at about 51 mph at 6500rpms. And correct me if im wrong but isnt there a rev limiter at 7300 or is that just the manuals? Whatever it is i hope you get it figured out and hopefully it wont cost too much. Good luck.
2005 Saturn Ion Redline - Injector Dynamics 1000cc Injectors|E85|Harrop TVS1320 Blower|2.9" pulley|3" Intake|Vibrant Header and catless Downpipe|Hahn 3" catback|N2MB Wot Box w/2-step and no-lift shift|Cobra Heat Exchanger|Hurst STS|Ottp Stage 1 trans mounts|AEM EUGO Wideband|Aeroforce Interceptor|HPTuners (self tuned)|Mop Top Pros Carbon Fiber badges|B&G Springs
Old 06-07-2006, 10:30 AM
Damn someone beat me to it...
I always wondered why people try and shift in ATX (at least pre-"manumatic")... All this time the engineers spends tuning the hydraulics to try and match the proper WOT shift points and then someone tries and "outsmart" it... What a waste.
Anyway, the rev limiter is just the fuel cut off... You can force the engine to go faster if the transmission is in the wrong gear because the fuel is not longer what is controlling the engine RPM at that point (IE: it's now the enertia of the car... gasp, phsyics terminology!)
Old 06-07-2006, 10:37 AM
Just incase anyone still thinks they are better at shifting than their auto trans.
What you do is push it forward, you dont have to push in the button. Here is how autos are GENERALLY designed. You need to push the button, or pull back if its on the column, to get out of park. From reverse you can shift to neutal and drive without pushing the button, but you can only shift from drive to neutal without the button. This is incase you need the car out of gear quick you just slap the stick forward and it stops in neutral. Now if you put it in 1 you can shift to 2 without pushing the button in, but you cannot shift back to 1 without the button. Ditto for 2nd to 3rd, and 3rd to 4th.
All of this generally makes the car slower, even when shifting a manumatic trans it will make you slower than if you just let the computer decide when to shift.
Old 06-07-2006, 04:52 PM
Zeiss's Avatar
Zeiss Zeiss is offline
our cars are becoming too cheap...
Bye V8...
Old 06-07-2006, 04:59 PM
i think you mean inexpensive..cause my car is far from cheap
