Old 06-06-2006, 01:04 AM
drdd's Avatar
drdd drdd is offline
relay ? multi-function? DRLamps?
well ... just got back from an hour-long drive ...
all of a sudden, I noticed that the DRLamp light on the dash would blink intermittently ... I would also hear an intermittent click from the glovebox ...
this happened only 4 times ... kinda random ...
any ideas?
relay ? multifunction switch?
no codes. 97 Jimmy ...
Old 06-06-2006, 07:53 AM
muzzy1maniac's Avatar
muzzy1maniac muzzy1maniac is offline
Re: relay ? multi-function? DRLamps?
Check this post out for instructions on how to clean your multi-function switch...
http://www.automotiveforums.com/vbul...multi+function
2004 Explorer XLT
4.0L 4x4
1998 Ranger Supercab
4x2 3.0L
Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store!
Come visit me on www.faceforums.com
Old 06-06-2006, 08:58 AM
joeuser742 joeuser742 is offline
What's a DRLamp?
1998 Blazer 4WD 4.3L 118,000miles 4dr
Repairs
--rear main seal, u/l ball joints, pitman/idler arms, i/o tie rod ends, control arm bushings, motor/trans mounts, oil relocation lines, door pin bushings, water pump, ring/pinion.
--Bad ABS ground, loose connection blower motor, repaired pulse board.
Mods/upgrades
-Throttle plate mod.
1999 Ford Windstar SE 3.8L 160,000miles
Repairs
--P171/P174 procedure, loaded control arms, tie rod ends, shocks, struts, springs.
Old 06-06-2006, 12:07 PM
blazee's Avatar
blazee blazee is offline
Problem?
Originally Posted by joeuser742
What's a DRLamp?
The instrument panel indicator for the Daytime Running Lights.
Old 06-06-2006, 03:10 PM
Ahh. I couldn't figure that out. Hmm, then maybe there is a bad connection/ground somewhere. I remember seeing something about the hazzard switch going bad causing no brake lights, but don't remember what year that was for. I had a problem with a bad pulse board, I was getting the clicking behind the glovebox.
There is too much stuff on these Blazers/Jimmys that is all tied together. When one part fails it's because something else caused it.
Repairs
Mods/upgrades
Repairs
Old 06-06-2006, 03:51 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
When one light goes out, they all go out! Edith get me a beer!!!
I removed the fuse for my DRL so they no longer turn on
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 06-07-2006, 10:16 PM
drdd's Avatar
okay here's an update...
I walk out tonite after work and my headlights and brights don't work.
so, again,
I've now seen the flickering DRLamp on the dash (and heard the clicking sound in the glovebox) about 4 times.
Now tonite, no headlights or brights.
all other lights and accessories are fine.
swapped relays in the glovebox with no results.
all fuses are good.
would the dirty multi-function switch still cause this?
Old 06-08-2006, 05:57 PM
drdd's Avatar
okay, I've got the multi-function switch off the column. It's still connected to the harness wires.
sooo , what is it I'm supposed to clean? the wire contacts to the harness? they look okay to me ...
I began opening up the bottom plastic lid, but I was afraid of losing the small springs inside ... looks like mostly plastic anyhow ... is that what I need to clean?
EDIT: okay, I got the lid open and can see the copper contacts under the plastic BUT, I can't get the while plastic thing completely out. Same as in muzzy's link ...
guess I'll just clean what I can and see what happens ...
EDIT: well it looks like I had two different problems. cleaning the multi-function switch seemed to solve my clicking glovebox and flickering DRLamp indicator but not the headlights. As far as the headlights, I tried to take apart the switch and clean it but that didn't do the trick. Advance Autoparts had a new switch for $21 and everything's working fine now. I'll put back all the trim tomorrow when there's more daylight.
