Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 06-05-2006, 10:44 PM
Northern Sun's Avatar
Northern Sun Northern Sun is offline
Send a message via AIM to Northern Sun Send a message via Yahoo to Northern Sun
A/C fix it or not
Since im working on my engine and everything is stripped, i got access to a/c motor or whatever is called; its all covered in grease/old oil but i think i can all clean it off; how many of U are successfull with a/c fix ups? is it even worth fixing?, i got 90 with v6, thanks, N.S
Vietcong 3VZ-E
Old 06-09-2006, 07:00 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: A/C fix it or not
If it doesn't work, then it is likely that you need freon. After your engine is running, see if adding freon helps get the A/C get running.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 06-09-2006, 08:05 PM
thanks Brian; i found some info A/C conversion hmm ... still dont know if should i bother, ill have to read up a little bit more about ac system, thanks again
Vietcong 3VZ-E
Old 06-11-2006, 05:00 PM
Doittommarow Doittommarow is offline
Send a message via AIM to Doittommarow
Ah, the age old question, to fix, or not to fix. A/C work tends to be very expensive, but it depends on what needs to be serviced. It may be something simple like low or no freon (best case scenario) or a bad compressor. If you do decide to fix it, make sure you have the system tested for leaks so all the freon doesnt just leak right out. Here in Arizona I don't think I could handle not having a/c especially during summer, but I've always had a car with ac so im used to it.
At 3.15 a gallon for gas I figured it was the perfect time to buy a 4x4 truck.
Old 06-11-2006, 05:57 PM
i already take it out, oh well ... i dont think i need it that much
Vietcong 3VZ-E
