Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-05-2006, 11:25 PM
SySt3mR00t SySt3mR00t is offline
Send a message via AIM to SySt3mR00t
20g or t3/t4 ?
ok i am having difficulties finding out what turbo would be ideal with my mods, can somebody please help ?
Wiseco Stroker Pistons Eagle Rods With ARP Rod Bolts ARP Head Studs Cometic Head Gasket Ferrea Valvetrain .20 Bored 4g63 Block Shaved Head 4g64 Stroker Crankshaft Archer Racing 2 1/2" Downpipe AEM Fuel Pressure Regulator
B&M Short Shifter
Buschur Racing 2 1/2" Test Pipe
EVO III 16g Ported and Clipped Turbo
Buschur Racing Ported Exhaust Manifold
Buschur Racing Ported O2 Sensor Housing
XTD Stage 3 Clutch XTD Lightweight Flywheel Unorthodox Lightweight Underdrive Pulley
DSMLink Programmable ECU
Energy Suspension Motor Mount Inserts
GReddy Power Extreme Exhaust (with custom 4" square tip)
GReddy Upper IC Pipe
GReddy Front Mount Intercooler
GReddy Type-S Blow Off Valve
Magnecor Competition Ignition Cables
MSD DIS-2 Digital Ignition
NGK BPR7ES Spark Plugs (One Range Colder)
Open End Air Filter
Quaife Limited Slip Diff
RC Engineering 550cc Fuel Injectors
Removed ECU Speed Limiter
Road///Race Denso Fuel Pump
Web Cams 546/547 Race Cams (272° intake/256° exhaust)
Joe P Manual Boost Controller Brembo Drilled Rotors Hawk Brake Pads Battery Relocated To Trunk (Needed Space For Ignition) Dual Battery Selenoid Battery 1: Optima Yellow Top Battery 2: Optima Red Top
17" Enkei Shogun wheels wrapped in Dunlop SP8000 (215/45/Z17)
Eibach Pro-Kit Performance Springs
Koni Yellow Shocks/Struts
Freedom Design Front Strutbar
Pilot Motorsports Rear Lower Strutbar
which turbo should i use ?
96 GST
Old 06-06-2006, 12:00 AM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: 20g or t3/t4 ?
What are your goals?
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 06-06-2006, 12:05 AM
gstclips gstclips is offline
Send a message via AIM to gstclips
Re: 20g or t3/t4 ?
I say go t3/t4 if you are looking for high numbers. Most people I know with the 20g upgrade to t3/t4 anyways, and you are definetly set up for it.
THE OFFICIAL AF PIMP! - love EclipseRST[Banned]
1997 Gs-t Eclipse
6 bolt + other toys
Currently 295whp
Old 06-06-2006, 02:20 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: 20g or t3/t4 ?
Is that actually your mod list or is that what you want? 2.5" exhaust will not suffice on a big turbo with a stroker. You will need 3". DSMlink isnt a new ECU, just a way to modify the stock one and you can get rid of the top speed limiter with that. Those 550's wont even be able to max out a 16g, you'll need to get much bigger ones.
I say a bigger t3/t4, I dont think the 20g is really enough to make use of that kind of a list.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 06-06-2006, 08:11 AM
Re: 20g or t3/t4 ?
those are all already on my car ... so how big injectors should i need ... and i have been looking at 3 inch ... i am just waiting to order everything at once
96 GST
Old 06-06-2006, 08:19 AM
Re: 20g or t3/t4 ?
also .. wat do u guyz think about these injectors ... somthin isnt quite right about the price .. should i trust them .. http://shop.edoperformance.com/produ...oducts_id=1881 ... they are a set of 800cc injectors for under 200 bucks .. can this be ?
96 GST
Old 06-06-2006, 09:39 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: 20g or t3/t4 ?
MY personal opinion is that a GT35R type turbo is the smallest you should go with on a stroker. Full boost at 3700 rpm. Going lower than that isn't necessary, IMO, but if you want to the smaller GT30s work too. The 20g and t3/t4s below the 60-1 are too small for a stroker IMO. The 60-1 is a little smaller than a GT35R.
And of course, fuel system parts have to be sized to the turbo, so you have to take care. 950s should be the minimum, especially with DSMink. The Denso pump won't cut it, you'll need a 255lph, and only the high pressure unit will suffice.
It's important not to forget that 15-20% more displacement means 15-20% more airflow at the same boost, so turbos become much smaller Building a stroker is much more than just shortblock work, the whole setup has to be geared towards the added displacement...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-06-2006, 10:15 AM
Re: 20g or t3/t4 ?
arent 950's a little to big for my daily driver ... and also .. from wat i understand i should be able to max out the 16g with my 550's ... im not sure tho .. is this injector choosing chart in the middle of RRE's website misleading ? http://www.roadraceengineering.com/eclfuel.htm ... Also, for now wat should my fuel pressure regulator be set at ? 2.3l stroker, 16g, 19psi, 550cc injectors .... does anyone have an equation or can tell me from experience? Thanks Alot guyz !
96 GST
Old 06-06-2006, 10:31 AM
AF - Advisor
Re: 20g or t3/t4 ?
Fuel pressure should always be set to what the ECU expects it to be at, since it has no idea what it is if you change it
550s will not fully support an EVO3 16g.
950s will run like stock with DSMlink.
That chart on RREs page is a generalization.
Kevin Jewer
Old 06-06-2006, 11:43 AM
Thor06's Avatar
Jizzed In My Pants
Re: 20g or t3/t4 ?
I would stay far far away from those injectors. 800's for $150? I bet they arent worth their weight in shit. Stick to FIC, RC, or PTE for injectors.
Old 06-06-2006, 12:37 PM
Re: 20g or t3/t4 ?
i am sorry for this question .. i will probably seem really dumb ... but i am not fully understanding it ... how do i know what the ECU expects it to be set as? is there an equation ?
96 GST
Old 06-06-2006, 12:49 PM
Re: 20g or t3/t4 ?
found out more information about those injectors ... well i found another website selling those injectors for an EVO for close to 700 bucks ... http://www.vividracing.com/catalog/p...ducts_id/12323 ... so i started wondering ... so i called the TX location of EDO Performance .. where the "Injector Set" says 158.40 ... well they told me it was NOT THE SET ! .. thats per injector .. now it all comes togethor.. they jus mis typed it on the website ... i wonder how many people got ripped on that deal .. isnt that like .. hmmm FALSE ADVERTISING ! ... well just thought i would let you guys know that , the price is PER INJECTOR .. not "SET" as stated on the website.
96 GST
Old 06-06-2006, 02:01 PM
blk_srt's Avatar
Re: 20g or t3/t4 ?
The ecu expects to see what it was programed to see which is 43.7psi at base idle I believe
Mods:
Old 06-06-2006, 08:19 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: 20g or t3/t4 ?
I hope you plan on upgrading your wheels/tires with that kind of a setup. You'll burn off anything and everything that isn't a drag tire in no time.
33 at idle with vacuum at pressure regulator, 42-45 without vacuum at pressure regulator.
95 Talon TSI AWD
97 Eclipse GST
Old 06-07-2006, 12:46 AM
Thor06's Avatar
Jizzed In My Pants
Re: 20g or t3/t4 ?
I dont really care what those injectors are going for anywhere else, I wouldnt mess with anything other than PTE, RC, or FIC.
